It is currently Mon Oct 26, 2026 7:51 pm
Vehicle: 09 Jimny JX
Post Posted: Mon Jul 28, 2014 6:23 pm
hey guys, mid way through my M16a conversion and have a few queries
is it advisable to block off the coolant lines running to the throttle body?
i want to use the coolant IN and OUT to plumb up the factory oil cooler (i hope it works that way)
also the water pump is completely different between the 13 and the 16. (i've used the 16 one, it sounded quieter)
Post Posted: Mon Jul 28, 2014 7:39 pm
Why do you want to run the oil cooler to the TB?
When I swapped in my 1.8 I used the coolant pump that came with it, I just swapped the back housing from 1.3 which just bolted up.
Post Posted: Mon Jul 28, 2014 7:47 pm
not to the throttlebody itself, but to where the throttlebody hoses go into the block., disconnect the coolant lines to the throttlebody and use them to plumb the oil cooler?
if that makes sense
Post Posted: Mon Jul 28, 2014 7:53 pm
Yeah now I get it, what about a "T" junction so both will function?
I think Paulw disconnected the coolant hoses to TB but I do wonder how/if the idle would be affected at warm up to operating temp.
Platinum Supporter
Platinum Supporter
Vehicle: 2010 jimny
Post Posted: Mon Jul 28, 2014 9:24 pm
did i miss the memo is it snowing in brisneyland?
Post Posted: Mon Jul 28, 2014 9:40 pm
It does happen Jezza, rare but it happens.
My idle takes a minute or so for enough warm coolant to release the IAC to drop idle rpm, without the coolant flow and just relying on manifold temp it would take longer.
Post Posted: Tue Jul 29, 2014 7:11 am
is the coolant warming a wax pellet type idle up thing like G series and carbies have or is it an emmisions thing to warm the intake?
Post Posted: Tue Jul 29, 2014 7:33 am
It seems to warm the back of the IAC valve
Post Posted: Tue Jul 29, 2014 9:43 am
I would be inclined to plumb them in series, go from block, through throttle body, through oil cooler and back to block, will work just as well and you don't have extra fittings floating around
Post Posted: Tue Jul 29, 2014 12:49 pm
GOD DAMMIT why didnt i think of that! i've T peiced off the throttebody lines
Users browsing this forum: Google [Bot] and 291 guests
