It is currently Tue Oct 20, 2026 12:31 pm
Post Posted: Fri May 01, 2009 12:30 am
i am going to put a g16 carby motor in my sierra this weekend and have a couple off questions.
the motor i have has what looks to be a falcon carby on it and i want to run
a suzuki carby. i have bought a vit carby through outers however it looks
like it will be a while until i get it. if i run a sierra carby would i be better running the sierra intake manifold? will a sierra carby bolt up to a vit manifold? is this manifold a vit one?
also i am sticking a 110amp alternator on, would i be right in guessing that
if i get the wires around the wrong way smoke wont come out it just wont work
and if that is the case i can just swap them around and the other connection goes to the battery. the only fuse like i could find was 30amp does that mean
if i put 4 lengths of fuse link together it will be 120 amp?
Post Posted: Fri May 01, 2009 12:50 am
Sierra carb will work, look for the thread on here about nissvit rejetting Steves to make it go better :)
right on the alt, 2 wires, 2 spots, if the warning light doesnt come on its wrong :) dont worry about the fuseable link, youll be right :)
Post Posted: Fri May 01, 2009 2:47 am
thanks mate
Post Posted: Fri May 01, 2009 4:11 pm
i also have to swap pulleys on the air con compressor and as i want to
leave the system gassed what is the best way to get the pulley off. i cant hold it when i use a spanner, will it be ok if i just up it with a rattle gun?
Vehicle: '92 Sierra
Post Posted: Fri May 01, 2009 4:42 pm
If its got openings in it like a vit power steering pump I usually just put a screwdriver through and lever that off the case while I turn the spanner. Otherwise I don't see why a rattle gun would wreck it. Thats all I use on alternators and it doesn't wreck them.
Post Posted: Sat May 02, 2009 2:36 am
rattle gun fixed it. :lol:
Post Posted: Sat May 02, 2009 1:59 pm
more problems
the crank pulley is rubbing on the timing mark and the idler pulley
is about 4mm out of line to the crank pulley.
i can ether space the crank pulley out a few mm but that is probably dodgy?
or i can toss the swift compressor mounts and reuse the 1.3 mounts.
the prob with the 1.3 mount is that the top bracket wont bolt up to the compressor so i would need to make some sort of bracket for adjusting the compressor belt.
what do people suggest?
Post Posted: Sat May 02, 2009 2:20 pm
Big hammer
Post Posted: Sun May 03, 2009 4:10 pm
could you not use a thinner multi v belt and just run it on the grooves that match up?
[quote="zookieboi"]has anyone really been far even
Post Posted: Sun May 03, 2009 4:18 pm
i actualy made a spacer for my gti motor out of 6mm flat..
i had the same issue. i spent a fair while making it nice and square. it appers to work, although i haven't driven it on the road yet..
here is a pic
Post Posted: Sun May 03, 2009 5:01 pm
the thing with my pulleys is that the water pump and alt pulleys line up
with the crank pulley it is just the air con compressor that i am having problems with. i will worry about it when i get the motor in the car as the
compressor is still gassed up.
Users browsing this forum: No registered users and 193 guests
