It is currently Mon Oct 26, 2026 12:04 am
Vehicle: 1995 SWB Sierra TinTop
Post Posted: Sun Aug 10, 2014 10:28 am
Hey guys!
Just finished my G16b conversion in my Zook
It's idling around 1500rpm at a constant level
Yes I've searched this
Is there anyone around brisbane that tunes these so I can lower the rpms?
Vehicle: 85 ' Drover
Post Posted: Sun Aug 10, 2014 10:57 am
You don't need a tune, you need to find the idle screw and adjust it, or find the leak that is letting air into the intake manifold.
Post Posted: Sun Aug 10, 2014 11:02 am
Tried that screw mate
And there's no leaks, look for that also
Post Posted: Sun Aug 10, 2014 11:21 am
Hmm well you cant tune the ecu or anything.
You can make sure the intake air control valve is working correctly? Sometimes they get blocked up.
Have you bled the coolant system properly?
Post Posted: Sun Aug 10, 2014 11:28 am
Oh ok
Yeah I have I pulled it apart yesterday and cleaned it up, I may have to do that again, I pulled the hose off the outlet side of it and heaps of water smashed out of it so it can't be blocked
Post Posted: Sun Aug 10, 2014 11:41 am
It's only running extractors ATM with no 02 sensor in them yet, would that matter?
Vehicle: zook
Post Posted: Sun Aug 10, 2014 1:05 pm
I would say that certainly matters. The ECU is looking for the sensor temp to come up first.
If you are not using the donor cars dash then you might not be seeing it throw a code for the o2 sensor.
It is a vital part of the EFI and emissions system.
Post Posted: Sun Aug 10, 2014 2:17 pm
No worries mate
I am getting a exhuast system Wednesday!
And I will see how it goes
But any more suggestions will be most welcome
Post Posted: Mon Aug 11, 2014 7:34 pm
I don't run a o2 sensor in my g16b. I have the CEL hooked up and it doesn't come on - it idles at 1000rpm. Is your throttle cable adjusted correctly?
Post Posted: Mon Aug 11, 2014 7:58 pm
Don't worry it'll pop up once you go for a descent drive :wink:
Users browsing this forum: No registered users and 93 guests
