Vehicle: Sierra sj80
Posted: Fri Aug 15, 2014 6:01 am
fitted the eos cradle in no worries but now i've found out the coily flanges are threaded but my leafy case flanges aren't, what do you leafy drivers have fitted just bolts with nylock nuts on the other side? Or should i try and swap the flanges to the old coily ones?
I had the same issue with mine, used new nuts, bolts and washers. You have to get the correct length bolt aswell. Too long and they will hit the flange and you wont fit a nut on the end.
Users browsing this forum: No registered users and 199 guests
