It is currently Mon Oct 26, 2026 3:09 pm
Vehicle: 1984 holden drover (lwb zook)
Post Posted: Mon Sep 08, 2014 5:30 pm
hey guys
I have a zook with nt diffs but i want to swap to wt diffs so i can put in air lockers and chromoly axles is there a cheaper way or easier way then swapping hole diffs? can i just swap diff centers to wt diffs so i can fit the lockers and rear side gears for the chromolys? or would the wt center not fit in? just want some general info on the subject and anyone that has done it before maybe give some advise or knowledge.
Thanks :peaceout:
Post Posted: Mon Sep 08, 2014 5:33 pm
The whole point of going wt is to gain more width and spring clearance for fitting larger tyres... Also chromos and floater kits come as a added bonus...
Post Posted: Mon Sep 08, 2014 5:38 pm
how much wider is the actual diff housing though? because i can fit the tires now i just want to lock it and make it stronger, if transferring the hole diff is the only way i will do it but just seeing if there is other options
Vehicle: Drover pickup turk
Post Posted: Mon Sep 08, 2014 5:41 pm
Just under 100mm wider.
I like the tuna here
Post Posted: Mon Sep 08, 2014 5:42 pm
I can make narrow track chromos if you wanna stay narrow track. Then you just throw a 26 spline locker in and away you go
Post Posted: Mon Sep 08, 2014 7:20 pm
How much for a set of NT 26 spline rears?
Post Posted: Mon Sep 08, 2014 7:27 pm
here is a sweet guide on doing the NT to WT diff swap viewtopic.php?f=14&t=5293
thanks bogfrog for your mighty fine work. :wink:
Vehicle: sj51
Post Posted: Mon Sep 08, 2014 7:34 pm
My only reasons to go wide track was for off the shelf cromo axles and to run wheels with no offset or a small positive offset to reduce wear on bearings, kingpins ect..
Width and spring clearance wernt a issue with my 33's
Post Posted: Mon Sep 08, 2014 9:13 pm
got any photos of the chromos you make? and are they 33 spline and 26 spline inner? would they run 33s just fine?
Would a normal locker or 26 spline side gears fit in a nt diff?
and yeah i recon i would be the same
Post Posted: Tue Sep 09, 2014 8:11 am
NT rears are already 26 spline and should be plenty strong. I do have plans to do NT floaters though
They are not 33 spline at the CV as I never saw the point. they fit the 25 spline silverback chromo cvs from lowrange.
I am waiting on a set to come back from the heat treaters at the moment.
Post Posted: Wed Sep 10, 2014 7:28 pm
I'm talking about chromo NT rears?
I'm feeling pretty sceptical about mine lasting with air lockers and 33's
I've got WT chromos in the front already.
Post Posted: Thu Sep 11, 2014 7:32 am
Standard rear axles are a lot stronger than you might expect.
I ran 32 simex pedes without a breakage and I drove it like it was stolen.
Post Posted: Thu Sep 11, 2014 8:05 am
yep standard rears are quite strong.
i'll be doing floaters at some point if I can ever find the time
Post Posted: Thu Sep 11, 2014 8:21 am
NT seem to be stronger than WT rear. Not sure why- shouldn't be the case, but it's what I've observed.
Post Posted: Thu Sep 11, 2014 8:30 am
our LJ rears seem particularly strong. we put it down to having centred diffs and axles the same length both sides.
Users browsing this forum: Google [Bot] and 238 guests
