It is currently Wed Oct 28, 2026 11:17 am
Post Posted: Thu Sep 04, 2014 4:44 pm
Hey gang,
As I have led indicators all round on the ute they don't flash at all. What do I need to make them flash? Flasher unit from supershit do the job?
Vehicle: '94 suzuki maruti
Post Posted: Thu Sep 04, 2014 5:10 pm
they make flasher units designed for led lights, or you can use those resistors in parallel with each light. i always found this to be a little dodgy looking though, and would work out expensive.
Post Posted: Thu Sep 04, 2014 5:29 pm
day already flash cuz ;)
but serious, flasher unit for LED's or load resistors
Vehicle: 89'SWBsierra&84'LWBsierra
Post Posted: Thu Sep 04, 2014 6:56 pm
I brought a cheap LED flasher unit to suit the sierra plug configuration from china, and guess what? it didn't fit so I had to trim it back so it did and it didn't work. I am going to head to jaycar and get one from there
Vehicle: 1991 swb vitara JLX
Post Posted: Fri Sep 05, 2014 4:42 pm
flasher unit will only slow the rate of flash down.... if it dont flash ..dont think it will make it do it...but i might be wrong
Post Posted: Sun Sep 07, 2014 1:13 pm
Ok so I got a flasher unit from a mate, stupid question where is the flasher unit located in the harness?
Vehicle: Drover pickup turk
Post Posted: Sun Sep 07, 2014 1:36 pm
Above the accelerator pedal with the fuse box.
I like the tuna here
Post Posted: Sun Sep 07, 2014 7:44 pm
Tried a 3pin flasher unit and no go. It was a 30watt and the stock unit is 27watt. Would that make a difference?
Post Posted: Sun Sep 07, 2014 7:54 pm
Haven't blown a fuse?
Post Posted: Sun Sep 07, 2014 7:59 pm
Wattage won't make a difference. Probably better off getting some resistors from Jaycar and wiring those in and use standard flasher unit
Post Posted: Sun Sep 07, 2014 8:01 pm
Nope cus it they still lite up with the original unit in
Ok thanks scrawn I'll give that a crack
Post Posted: Sun Sep 07, 2014 10:03 pm
What ohm/watt resistor do I need?
Post Posted: Sun Sep 07, 2014 10:10 pm
I tryed the jay car ones and they didn't work... So bought a set of narva ones from supershit. And the worked a treat...
Vehicle: 00 Jimny, 63 Haffy
Post Posted: Mon Sep 08, 2014 10:22 am
Most of the flasher units on the shelf are wired backwards to the ones in a sierra. The left and right pins are swapped. I ran one with some jumpers for a week or so while I got one the right way around.
take a look at the pin layouts before you order another.
Post Posted: Mon Sep 08, 2014 8:08 pm
Got some resistors today and wired them in. They all flash now, just a bit faster than normal globes but none the less they flash. Thanks the help zookers :peaceout:
Vehicle: Sierra sj80
Post Posted: Wed Sep 10, 2014 5:45 pm
I had to get 2x 12w load resistors on each blinker to get mine back to spec, there is a specific rule to how many flashes per min in nsw for it to pass rego.
Users browsing this forum: Google [Bot] and 334 guests
