It is currently Mon Oct 26, 2026 12:07 am
Vehicle: LWB Sierra & XL7
Post Posted: Thu Sep 18, 2014 5:17 pm
I mounted the calmini transfer cradle but the drum brake hits one of the brackets, so what do you think is the better option?
Chop it
Use a LROR "EOS" transfer cradle
Spidertrax disc conversion - although I can't find anywhere that sell them now.
Or other?
'92 Vitara & Camper trailer
Post Posted: Thu Sep 18, 2014 5:43 pm
WT diffs? use the standed WT handbrake?
Post Posted: Thu Sep 18, 2014 6:01 pm
you will need wide track backingplate assemblys and have to put them on narrow track axles. which means new bearings/collars too.
dont think widetrack diffs will work as the hangers are in a different spot
then you still need the handbrake cable ect..
Post Posted: Fri Sep 19, 2014 8:25 am
your right, no one has ever put WT diffs in an NT before.
Post Posted: Fri Sep 19, 2014 9:07 am
If you're not going to WT diffs I'd trim the bracket to fit. Dank also put up a how to for a cheap transfer disc brake a long while ago.
Here it is: viewtopic.php?f=14&t=23034
Post Posted: Fri Sep 19, 2014 3:42 pm
I've gone with WT diffs but retaining the transfer handbrake as I'll be using the sierra front calipers / disc setup on the rear.
Post Posted: Fri Sep 19, 2014 3:57 pm
:P
Vehicle: Drover pickup turk
Post Posted: Fri Sep 19, 2014 4:05 pm
Chop it.
EDIT: http://nbs4x4club.com/forum/index.php?topic=14186.270
I like the tuna here
Users browsing this forum: No registered users and 88 guests
