Page 1 of 1
[ 5 posts ] |
Print view
Previous topic | Next topic
| Author |
Message |
ozzoot
Vehicle: suzuki sierra ute
 Posted: Mon Sep 22, 2014 7:31 pm |
hi new here hoping someone can help i have a maruti ute it was a 1000 cc motor, i changed to a 1.3 litre and 5 speed gearbox also put a 1.3 transfer box sj70 (as the 1000 litre transfer box died) but my problem is now my rear diff has done the pinion, it has broken 4 teeth. the crown has 45 teeth and the pinion has 11 teeth which would make it a 4.09 ratio. impossible to find? plus very slow on the road, so could any one tell me if a 3.7 diff would fit, or would it change the power to much?
whincup
Joined: Sat Apr 17, 2010 11:30 pm Posts: 1588 Location: Gracemere, QLD
Vehicle: '94 suzuki maruti
 Posted: Mon Sep 22, 2014 9:29 pm |
My maruti has a jimny diff centre in the back, after mine did similar... Jimny diff centre bolts straight into the housing (assuming yours is a wide track model?) but you'll need the flange off the jimny tailshaft, or remove the pinion flange and teplace with the maruti one...
ozzoot
 Posted: Tue Sep 23, 2014 7:32 pm |
thanks heaps for that, never even thought about trying a jimny . will try that thanks
mnemonix
Joined: Sun Aug 16, 2009 11:30 pm Posts: 1409 Location: Newcastle NSW
Vehicle: '96 LWB trayback
 Posted: Tue Sep 23, 2014 8:54 pm |
Jimny rear is the diff you want. You can use it in both front and rear of your maruti and the ratio is identical. Some people claim they're weaker than the maruti centre, Although I run 2 in my zook and have had no issues.
What is your tyre size? It may be to blame for you slow onroad manners.
_________________ Twin charged twin cam twin locked webwheeler
MrRocky
Joined: Thu Dec 17, 2009 10:30 pm Posts: 4731 Location: perth
 Posted: Thu Sep 25, 2014 6:38 am |
Ive sold alot of maruti diff centers to jimny owners
Page 1 of 1
[ 5 posts ] |
Users browsing this forum: No registered users and 199 guests
