It is currently Mon Oct 26, 2026 12:07 am
Vehicle: Coil Sierra
Post Posted: Tue Sep 23, 2014 6:39 pm
Im installing a 2nd tachometer to see if the factory one is reading correct.
The gauge is installed and just needs the signal wire hooked up. The gauge instructions say to join the signal wire to the negative side of the dizzy?
Is this correct or is there another wire i could get an rpm signal from?
G13ba engine
Post Posted: Tue Sep 23, 2014 6:42 pm
I thought you'd connect to the same point the stock tach is connected to - it's the brown/white wire connected to one of the terminals of the coil.
Post Posted: Tue Sep 23, 2014 6:44 pm
Thanks.
Users browsing this forum: No registered users and 92 guests
