| Tachometer signal wire location https://auszookers.com/forum/viewtopic.php?f=5&t=47895 |
| Author: | coily96 [ Tue Sep 23, 2014 6:39 pm ] |
| Post subject: | Tachometer signal wire location |
Im installing a 2nd tachometer to see if the factory one is reading correct. The gauge is installed and just needs the signal wire hooked up. The gauge instructions say to join the signal wire to the negative side of the dizzy? Is this correct or is there another wire i could get an rpm signal from? G13ba engine |
| Author: | Gwagensteve [ Tue Sep 23, 2014 6:42 pm ] |
| Post subject: | Re: Tachometer signal wire location |
I thought you'd connect to the same point the stock tach is connected to - it's the brown/white wire connected to one of the terminals of the coil. |
| Author: | coily96 [ Tue Sep 23, 2014 6:44 pm ] |
Thanks. |
