| tacho reading rpm's with engine off https://auszookers.com/forum/viewtopic.php?f=5&t=47909 |
| Author: | 4x4ewok [ Wed Sep 24, 2014 6:07 pm ] |
| Post subject: | tacho reading rpm's with engine off |
I am in the process of installing an g16b into my swb vitara and when I turned the key to on, the tacho jumps to 2000 rpm with out the engine running. I am guessing I have stray voltage coming from some where but I can't figure out where, tacho wiring is pretty straight forward. I also don't have lights come on for 4wd, L or battery, but I can live without these. However they may be related problems. Using the pin out and wiring diagrams I have I have run the multi meter over a few wires and the back of the cluster and everything there seems to be as it should, however I hate wiring and may have missed something. If anyone has any suggestions them please let me know. Cheers |
| Author: | J--A--C--K [ Thu Sep 25, 2014 1:04 pm ] |
| Post subject: | Re: tacho reading rpm's with engine off |
I'm not really a knowledgeable person on this but when i had a baleno 1.6 put in my Sierra there was a resistor that needed to be added / changed in the cluster So the rpm would read correct. May be of some help. |
| Author: | 4x4ewok [ Thu Sep 25, 2014 6:28 pm ] |
Thanks for the tip, I will do some research and see what I can find, however since its still a vitara I thought it would be OK? I have done some more poking around today and tried a few things. I disconnected the brown wire from the back of the speedo and tried power again and had the same result, so my indication isn't coming from that side of things. I have also checked the wiring at the engine end and can't findanything obvious there either. On the plus side, I discovered why my indication lights weren't working. I missed an earth for the 4wd lights and I forgot to change over the sense wire from the alternator from my old harness to the new one. |
