It is currently Sun Oct 25, 2026 12:59 am
Platinum Supporter
Platinum Supporter
Vehicle: 2010 jimny
Post Posted: Thu Oct 23, 2014 8:51 pm
Yo
so i have a new axle housing and diff centre im going to use as a rotable. this will make it easier to install and test everything is ship shape with the caplocker and fullfloat rear so i can just jack the rear of the car, drop out the current axle intact and connect up the new one, with one extra airline being the exception.
axle housing i have however is from a ABS jimny and mine is non-abs
so anyone got any ideas on what to do with said holes?
from what i understand on where they are its on the outside of the axle seal.
weld them up?
screw in pretend ABS sensors to confuse the transport people? (lol cos they do turn up once every 2 years)
any ideas? i assume a grease nipple is just a silly idea, as it would just pump lube into the spindle...?
Post Posted: Thu Oct 23, 2014 8:54 pm
bolt?
Platinum Supporter
Platinum Supporter
Vehicle: 2010 jimny
Post Posted: Thu Oct 23, 2014 9:18 pm
i expected more nipple related comments atari.
Post Posted: Thu Oct 23, 2014 10:47 pm
Just leave the ABS sensor in and cut the wires
Platinum Supporter
Platinum Supporter
Vehicle: 2010 jimny
Post Posted: Sat Oct 25, 2014 6:29 am
no sensors in it unfortunately.
Post Posted: Sat Oct 25, 2014 7:32 am
I'd just weld them up.
Vehicle: Suzuki Jimny 2010
Post Posted: Tue Nov 04, 2014 5:09 am
Weld it up. Bit of brass or copper behind it will make it easier to fill the hole. Bolts would be painful. Whichever way you do it needs to be waterproof... Your rear wheel bearing sits behind it
Users browsing this forum: Google [Bot] and 295 guests
