https://auszookers.com/forum/
LJ50 Flasher Relay
https://auszookers.com/forum/viewtopic.php?f=5&t=48300
Author:  bmugg [ Sat Nov 01, 2014 5:05 pm ]
Post subject:  LJ50 Flasher Relay
Hi All,
So I am slowly getting the LJ ready for roadworthy etc, anyone able to tell me where the flasher relay is??
Thanks
Author:  AckerDackerly [ Sun Nov 02, 2014 8:30 am ]
Post subject:  Re: LJ50 Flasher Relay
bmugg wrote:
Hi All,
Thanks
One of the great sources of information for the LJ series is the website http://www.lj10.com
the following diagram link (and the following page) may help you locate the turn/emergency flasher relay:
http://www.lj10.com/lj50info/lj50ownman/pg80.htm
I hope that this helps!
Author:  303zuke [ Mon Nov 03, 2014 10:21 pm ]
It's not like there's many places it can be! There's bugger all electrics in an LJ. Anyway, you will find it mounted on the firewall above the driver's right foot.
After all these years, it is possible the original relay has been removed and replaced with a standard flasher can. If you can't find it, turn on the hazard lights. You'll soon hear it.
Author:  bmugg [ Tue Nov 04, 2014 9:42 am ]
Thanks for that!! I think it is busted the indicators stay solid... Would this be the case?
Author:  303zuke [ Wed Nov 05, 2014 12:49 am ]
Sounds stuffed. Get a can type flasher relay to replace it.
