It is currently Sun Oct 25, 2026 6:02 am
Vehicle: 95 sj70 and 78 lj81
Post Posted: Sun Nov 02, 2014 12:53 pm
I have a leak due to the transfer case gasket deteriorating, has anyone sealed one up in situ or at least without taking the whole thing apart?
Vehicle: Suzuki Jimny 2010
Post Posted: Sun Nov 02, 2014 2:10 pm
Best off splitting the case and removing all the old gasket and then using some gasket silicon to reseal it.
Post Posted: Sun Nov 02, 2014 3:05 pm
Have you tried not splitting one to seal it?
Vehicle: WT sierra, GU CRD
Post Posted: Sun Nov 02, 2014 10:47 pm
How would you do that?
The previous owner of my motorcycle tried to seal the clutch cover by covering the underside in brown goop, obviously without splitting.
Needless to say, I didn't find much oil in there.
I love ZD30. :)
Post Posted: Sun Nov 02, 2014 11:17 pm
You could try draining the oil overnight, spray the crap outta the parting line that is leaking with degreaser, blow dry with an air gun and try jamming some ultra gray/black or any other quality oil resistant silicone in there.
Post Posted: Mon Nov 03, 2014 12:32 am
Transfers are fairly simple to take apart, I'd just bite the bullet and do that. It's probably never going to be right otherwise.
Post Posted: Mon Nov 03, 2014 6:59 am
Ah you guys
Simple but not always easy.
Time poor so it will be the ultra grey method. I have managed to split it about a 1/4 inch which should be enough to through some sploodge in. yes it wont last forever but it will prob last long enough.
If nothing else it will be a test case for others to learn from
Vehicle: LJ50 , LJ80Q-II
Post Posted: Mon Nov 03, 2014 1:01 pm
just food for thought
the transfer gasket is part of system for setting the gear mesh and preload .
Changing the thickness with gasket goo is going to change the gear contact pattern etc etc etc .
your transfer might get nosier , explode etc .
Post Posted: Mon Nov 03, 2014 1:11 pm
yeah good call, I think there is enough gasket there to keep the distance and meshing correct, its just needs a little help in some places
Post Posted: Mon Nov 03, 2014 2:32 pm
ive never run a gasket, nore bothered with preload on any of my cases and never had an issue.
Post Posted: Mon Nov 03, 2014 2:37 pm
what sploodge do you use?
Post Posted: Mon Nov 03, 2014 4:09 pm
grey or orange gasket goo. silicone.
Vehicle: X-90 + Lwb Sierra + DeVitt +++
Post Posted: Mon Nov 03, 2014 4:42 pm
Yes , I sealed my Sierra transfer that had started to leak by draining the oil ,cleaning where it leaked with some contact cleaner then spread silicone gasket sealant and attached the vacuum cleaner to the fill plug hole .
worked a treat .
Post Posted: Mon Nov 03, 2014 7:30 pm
Thanks MM
Its draining atm, i'll give it a clean and day or so to dry - only because Im doing other stuff
and sploodge it up
Users browsing this forum: No registered users and 121 guests
