[ 6 posts ] |
Print view
Previous topic | Next topic
| Author |
Message |
beef13
Joined: Sun Jan 04, 2009 10:30 pm Posts: 208 Location: Adelaide
 Posted: Sun Apr 05, 2009 10:19 pm |
a while ago i purchased a GME TX835 kit including mount and antenna, but it won't communicate with other radio devices, the receiving light is ALWAYS on, i don't know whether its where ive mounted the antenna (drilled straight into the bullbar) or what, but any help would be appreciated
royce
 Posted: Sun Apr 05, 2009 10:22 pm |
do you have other people you can test with that have AM CB's? dont expect to hear anything otherwise as AM CB is pretty well dead for vehicle communication
if its always showing recieving what audio are you getting? if its all whizzy and buzzy you are probably getting interference from the engine bay
beef13
 Posted: Sun Apr 05, 2009 10:32 pm |
yep, its all whizzy and buzzy, also when i turned on a vaccum cleaner near the car the fuzzyness went really loud.
as for other's CBs, the people i was driving with had handheld oned so im not sure
if i cant get it to work im thinkin bout buyin the TX4600?
royce
 Posted: Sun Apr 05, 2009 10:42 pm |
were they AM CB's though? thats what you have not a UHF one
TC4600 would be overkill really, but would do fine
GV_Sword
Joined: Wed May 13, 2009 11:30 pm Posts: 12 Location: Brisbane
 Posted: Fri May 15, 2009 12:19 am |
Your antenna probably needs to be tuned to suit your radio (SWF likely too high). Get in contact with someone at Delsound or even a Jaycar shop and they can help you sort it out. AM is still far better at UHF in long distance transmissions, if it's used correctly.
Pezooki
Joined: Wed Apr 15, 2009 11:30 pm Posts: 115 Location: SE Melbourne
Vehicle: 91 Sierra SJ70
 Posted: Fri May 15, 2009 1:01 pm |
Hi beef13.
Your radio is a 27Mhz CB. The static you are hearing is normal. You can use the SQUELCH to avoid hearing this.
The fact that your vacuum cleaner made the radio noisier is a good thing. It means that your radio IS receiving something. (It is normal for appliances such as vacuum cleaners to have this effect on 27Mhz radios).
Your problem seems to be that everyone you are trying to talk to has UHF CB (477Mhz) radios. Your radio is NOT compatible with these. My advice is get rid of the GME TX835 27Mhz CB and antenna that you have now, and go and get a UHF CB (like the TX4600 you mentioned). You MUST get a new UHF CB antenna too - your existing 27Mhz one is NOT compatible with a UHF CB!
Good luck!
Pez
_________________ 91 Sierra soft-top.
[ 6 posts ] |
Users browsing this forum: No registered users and 74 guests
