It is currently Sun Oct 25, 2026 6:03 am
Post Posted: Sat Nov 15, 2014 8:11 pm
Hey guys, as the post suggests I'm buying a jimny and I need a little help. My concern is that every jimny I have looked at has either a transfer or gear box leak (oilly box not really dripping on the ground) ive looked at 3 different ones today and they all apeared to have this problem. My question is this a really common problem and if there is any thing I should look at.
Ive been around sierra's a long time but this is my first encounter with the Jimnys, Im also pretty handy on the spanners.
Vehicle: Jimny 08'
Post Posted: Sat Nov 15, 2014 8:25 pm
Not that i have a huge amount of experience with car mechanics, but when i was buying mine, i wanted it to have a full service history, mainly because it meant the previous owner wasn't a tinkerer and didn't take bit and pieces apart doing their own services. But really depends on how much you are willing to spend i'd say.
edit: i didn't encounter any leaks when i was buying but was looking at relatively new models no less than 4-5 years old at the time.
My Jimny
Post Posted: Sat Nov 15, 2014 8:36 pm
yeah one of the jimny i looked at today was 2009 with one owner, an old guy thats never taken it off road and it had a fair amount of oil coming from the top of the gear box on the tail end (no oil any where near the motor of bell housing)
Vehicle: Jimny 08'
Post Posted: Sat Nov 15, 2014 9:50 pm
Ah weird, i was lucky with my jim, its an 08, been keeping it serviced and no problems/ leaks so far, definitely can't complain, also i haven't heard about any oil leak problems that are a common occurrence, but apart from that someone here might be a bit more help haha
My Jimny
Vehicle: 85 ' Drover
Post Posted: Sun Nov 16, 2014 9:40 am
What's on the back of the engine head? Cause if something is leaking up there if can drip down all over the gearbox.
Vehicle: SJ80, SE416
Post Posted: Sun Nov 16, 2014 11:07 am
JMO - if an oil leak isn't bad enough to leave oil on the driveway when parked overnight then it isn't worth worrying about - enjoy the free rustproofing.
Post Posted: Sun Nov 16, 2014 4:11 pm
Nothing on the motor only top of gear box near the back of the box
Post Posted: Sun Nov 16, 2014 6:10 pm
Are you sure it isn't grease off a tail shaft?
Vehicle: Suzuki Jimny 2009
Post Posted: Sun Nov 16, 2014 6:31 pm
My 2009 model has no oil leaks at all but has done about 36,000 km. The front shaft has a grease point and if too much grease is pumped in it will flick all over the place as it comes out.
Post Posted: Sun Nov 16, 2014 8:54 pm
I know they have a rear gearbox seal problem, have a look through zukenutter's thread when he blew his gearbox up. I think it's also a warranty claim jimny's have.
Post Posted: Mon Nov 17, 2014 12:01 am
Yeah, mine has the whole front tailshaft grease explosion thing happening too.
Post Posted: Mon Nov 17, 2014 1:07 pm
ITs a 2009 and from the look of it it has only happened recently as there is fresh oil and no dirt and grim caked under there in the oil so I suspect it would be the rear gear box seal
Post Posted: Mon Nov 17, 2014 1:09 pm
Ps I've bought that one with the leaky gearbox seal
Vehicle: Suzuki Jimny 2010
Post Posted: Mon Nov 17, 2014 4:00 pm
My 2010 has a leak out of the rear output seal. I'm pretty sure I've got a blocked breather. I've replaced the seal 3-4 times. It's an easy job, bout $6 for the seal from rep I and maybe an hrs work if that.
Users browsing this forum: No registered users and 117 guests
