https://auszookers.com/forum/
Belt tensioner Pulley bearing
https://auszookers.com/forum/viewtopic.php?f=5&t=48550
Author:  Xtreme [ Tue Nov 25, 2014 11:49 am ]
Post subject:  Belt tensioner Pulley bearing
Has anyone replaced the bearing in their tensioner pulley (AC and Power Steering 1999 Jimny)? Mine sounds like the bearing has issues and looking at the cost for a new pulley assembly $149! I wonder if anyone has pressed out the old bearing and pressed in a new one and if so do you remember the bearing you used?
Author:  droverdave [ Tue Nov 25, 2014 2:19 pm ]
Post subject:  Re: Belt tensioner Pulley bearing
Its more than likely a standard bearing size, so if you measure it and ring up a bearing shop they should be able to supply you with something that will work.
Assuming it can be pressed out/in etc.
Author:  flymaster [ Tue Nov 25, 2014 7:48 pm ]
Done it a few times on Toyota's, bearing cost around $9. Was told that the actual V pulley does suffer from wear in a high klm engine.
Nick
Author:  Xtreme [ Wed Nov 26, 2014 6:18 am ]
Ok thanks, I've taken then pulley off so will go to a bearing shop and see what I can find to suit
Author:  Xtreme [ Thu Dec 04, 2014 5:04 am ]
Cost for the new bearing was $15 as opposed to $130 for a new pulley and bearing from online. Very simple to tap out the bearing and tap in the new one now is running like a champion again.
Author:  GraphicX [ Thu Dec 04, 2014 8:58 am ]
i changed the pulley in mine not too long ago, sourced an ebay unit for about $50 so you're in front of me at $15.
Author:  Xtreme [ Thu Dec 04, 2014 9:19 am ]
That was for the whole pulley Im guessing? the $15 was for the bearing only as I did not need to replace the pulley
Author:  prolecs [ Sat Dec 23, 2017 1:16 pm ]
Bearing is 80mm OD, 50mm ID and 16mm wide. Sealed both sides.
6010 - (2RS - I think 2RS means it has seals both sides). Ask the bearing shop for best one to suit application
Author:  prolecs [ Sat Dec 23, 2017 1:17 pm ]
That's for M13A engine
