Joined: Wed May 16, 2012 3:46 pm Posts: 1691 Location: Brisbane
Vehicle: 99 Grand Vitara
Posted: Wed Nov 26, 2014 8:22 pm
Anyone experienced problems with one of their windows not working? I have traced it down to the wiring somewhere... Motor is fine, master switch is fine, and the driver rear switch is fine (window that doesn't work.) How I know is because I tested them on the twin.
Any ideas where I should be looking? I can't seem to get continuity from the master switch to the rear switch which makes me suspect that the wires are broken somewhere ;(
Posted: Wed Nov 26, 2014 8:47 pm
that's an odd one, you'd be going mad if you didn't have the twin to check against. i'd be checking the loom from the door into the A pillar on the drivers side first & see if it's pinched.
Users browsing this forum: No registered users and 176 guests
