| GV Power Window Problem https://auszookers.com/forum/viewtopic.php?f=5&t=48578 |
| Author: | klutched [ Wed Nov 26, 2014 8:22 pm ] |
| Post subject: | GV Power Window Problem |
Anyone experienced problems with one of their windows not working? I have traced it down to the wiring somewhere... Motor is fine, master switch is fine, and the driver rear switch is fine (window that doesn't work.) How I know is because I tested them on the twin. Any ideas where I should be looking? I can't seem to get continuity from the master switch to the rear switch which makes me suspect that the wires are broken somewhere ;( |
| Author: | atari4x4 [ Wed Nov 26, 2014 8:47 pm ] |
| Post subject: | Re: GV Power Window Problem |
that's an odd one, you'd be going mad if you didn't have the twin to check against. i'd be checking the loom from the door into the A pillar on the drivers side first & see if it's pinched. |
