It is currently Sun Oct 25, 2026 12:59 am
Vehicle: 1997 Sierra Convertible
Post Posted: Sun Dec 28, 2014 5:37 pm
Gday,
While checking the timing on my G13ba, my son and I come up with two completely different readings?????
The problem was, he was sighting from the top of the engine straight down and I was looking through the centre of the timing marks to the centre of the crank?
The timing marks are not straight on top of the crank pulley, but off to one side......about 11o'clock, so I assumed you need to sight from that angle, not straight over the top????
Can anyone tell me what is the correct angle as it makes a few degrees difference.
I can do a drawing if it explains it better.......
Vehicle: Drover pickup turk
Post Posted: Sun Dec 28, 2014 5:40 pm
Looking front on, the marks on the pulley/timing gear point to the marks on the block/head
I like the tuna here
Post Posted: Sun Dec 28, 2014 7:59 pm
Ill see if I can upload a drawing to explain myself better......
Post Posted: Sun Dec 28, 2014 8:05 pm
Post Posted: Sun Dec 28, 2014 8:06 pm
Should I be sighting along line A or B? It makes a couple of degrees difference?
Post Posted: Sun Dec 28, 2014 8:43 pm
A. same as looking front on.
Post Posted: Sun Dec 28, 2014 8:49 pm
Cheers....that's what I thought
Post Posted: Mon Dec 29, 2014 4:10 pm
Also - isn't there a port on the transmission housing on the exhaust side where you can see markings on the flywheel?
...or is this just on the SJ413 5-speed transmission...
Just curious - we don't have the cool stuff you have here in the Colonies... :x
-Ack
http://www.acksfaq.com
88, 88.5 SJ413
Post Posted: Mon Dec 29, 2014 4:35 pm
That was found on earlier models, what we call Narrow Tracks with the g13a
Users browsing this forum: Google [Bot] and 286 guests
