I was posting on here a while ago about troubles with my mass air flow sensor... I had an engine light cone on, she wouldn't idle, and when u push on the accelerator it coughs and splatters and I get a little bit of a backfire.
My engine light code told me it was "low signal from mass air flow sensor". I have replaced it, and the engine light is off, but it's still doing exactly what it was before..
I have changed fuel filter, new mass air flow sensor, cleaned the intake on throttle body with special sensor spray ($30 a can!!), checked all the air hoses for cracks/splits to no avail.
Please let me know if u can help....
P.s. do I need to disconnect my battery after installing the new sensor to reset the ecu??
Users browsing this forum: BZOOK, winchzook and 263 guests
