| SJ 80 Lower ratio Gears https://auszookers.com/forum/viewtopic.php?f=5&t=48984 |
| Author: | glenn.buttigieg [ Tue Jan 13, 2015 3:20 am ] |
| Post subject: | SJ 80 Lower ratio Gears |
is it possible just to reduce the ratio gears for the T case of the 4L and keep the same ratio for 2WD and 4H - I'm asking this as I use my SJ as a day to day drive and for some crawling in the weekends. And does any one suggest a particular ratio that will be ideal for this type of use given I have standard shafts & will be running a 4xfour Art Kit in the coming weeks. |
| Author: | want33s [ Tue Jan 13, 2015 5:30 am ] |
| Post subject: | Re: SJ 80 Lower ratio Gears |
Fit a leafy transfer case then you have a wide variety of reduction gearsets available. Check out www.lowrangeoffroad.com they have a chart on the website that shows all the different ratios available. |
| Author: | petes 80 [ Tue Jan 13, 2015 6:50 am ] |
is it a simple unbolt 1 and bolt in the other? |
| Author: | greenzook89 [ Tue Jan 13, 2015 8:26 am ] |
You need a WT (sj70) jackshaft and mounts. Then its a bolt in. |
| Author: | Gwagensteve [ Tue Jan 13, 2015 9:04 am ] |
But it will lower high range. I think Apio in Japan offer replacement planetary gears which will only lower low range. Expensive and not that low from memory. |
| Author: | greenzook89 [ Tue Jan 13, 2015 11:16 am ] |
Is that to suit the coily transfer steve? |
| Author: | Gwagensteve [ Tue Jan 13, 2015 11:27 am ] |
I believe so, but the whole APIO thing is a pain to deal with. Steve. |
| Author: | greenzook89 [ Tue Jan 13, 2015 11:47 am ] |
Seems a bit redundant considering anything bigger than a 215 is going to throw the high range gearing out of whack. |
| Author: | glenn.buttigieg [ Tue Jan 13, 2015 5:07 pm ] |
Thanks guys but is seems that the only way us to change the t case. .. but that will be lower the 4H & 2wd |
| Author: | greenzook89 [ Tue Jan 13, 2015 6:14 pm ] |
Correct. But only by a small percentage. Depending what tyre size you are running/what gears you get it may well bring it back to standard in high range. |
