It is currently Sat Oct 24, 2026 4:21 pm
lesspostingmorewheeling
Post Posted: Wed May 20, 2009 5:22 am
when rebuilding a 1.6 bottom end to use with a 1.3 head do i need to get a 1.3 or 1.6 gasket kit?
do i need to use a 1.6 or .13 head gasket?
Mike
Post Posted: Wed May 20, 2009 12:06 pm
Mike
I'd use the gasket to suit the bore size you have, in your case most likely 1.6 gasket.
1.3 uses a 74mm piston and a 75mm bore gasket, 1.6 uses a 75mm piston and 76mm bore gasket.
Oh, and FWIW, 1.6 and 1.3 heads (8v) are the same except for valve sizes, so the head doesn't really make any difference anyway.
Post Posted: Wed May 20, 2009 12:28 pm
I just rebuilt a 16V 1.6 with 1.3 8V head.
I bought a 16V gasket set and could only use from head gasket down. Had to buy rocker cover, inlet and exhaust gaskets to suit a 1.3 seperately.
If anyone wants what is basically a 16V VRS set minus head gasket, let me know.
Post Posted: Wed May 20, 2009 1:28 pm
That's got all the valve stem seals right? How much?
Post Posted: Wed May 20, 2009 1:39 pm
Yep, valve stem seals, rocker cover, inlet, exhaust, 4 larger rubbers that I think seal the plugs(not sure.. never checked out a 16V head) and a few other bits..
I dunno...Full set cost $120 I didn't even use half of it..
How does $40 sound?
Post Posted: Wed May 20, 2009 1:45 pm
Grab it Damo!! :D
Post Posted: Wed May 20, 2009 3:22 pm
im keen jason
Post Posted: Wed May 20, 2009 3:32 pm
11_evl wrote:
im keen jason
SOLD.
PM sent.
Post Posted: Wed May 20, 2009 3:55 pm
Bugger! Let me know if it falls thru.
Users browsing this forum: No registered users and 129 guests
