https://auszookers.com/forum/
Jimny rear axle
https://auszookers.com/forum/viewtopic.php?f=5&t=49049
Author:  Zook2510 [ Mon Jan 19, 2015 1:24 pm ]
Post subject:  Jimny rear axle
Hi all,
We're in need of a driver's side rear axle for our 2003 Jimny and we're having a bit of trouble finding one! Are these the same as a Sierra WT rear axle, or are they a different size or spline count? Any help would be much appreciated...don't want to go buy the wrong thing, cheers.
Author:  Gwagensteve [ Mon Jan 19, 2015 1:25 pm ]
Post subject:  Re: Jimny rear axle
Same spline count, different length. They are not interchangeable.
Author:  Zook2510 [ Mon Jan 19, 2015 1:38 pm ]
Righto, thank you!
Author:  Zook2510 [ Mon Jan 19, 2015 2:10 pm ]
Actually I should also confirm whether all Jimny rear axles are interchangeable? Ie. will an earlier or later model axle fit?
Author:  Mike57 [ Mon Jan 19, 2015 8:00 pm ]
I believe they are all the same but the later ones will have ABS rings fitted. I am yet to prove that this is true though.
Author:  Seth2013 [ Tue Jan 20, 2015 12:38 pm ]
I think anything pre-ABS is fine.
(depending where you are) I know of one, cause I've bought the left (passenger) side axle out of a wreck in cairns for my 2003 model. get a wheel bearing kit while your at it.
