| Manual Vacuum Hubs https://auszookers.com/forum/viewtopic.php?f=5&t=49066 |
| Author: | Seth2013 [ Wed Jan 21, 2015 9:26 am ] |
| Post subject: | Manual Vacuum Hubs |
Hi all Just wondering of any implications of putting the 4WD vacuum hubs onto a manual switch on the dash - Idea being I can run 2WD low, and then flick the switch when I want 4WD. Its no a 2003 jimny. background info - sierra transfer case soon to go in. I do have manual adapter plate rings ready to go, but I want to try retain the vacuum hubs (although potentially unreliable) for the time being. Thoughts appreciated. |
| Author: | sideways [ Wed Jan 21, 2015 11:18 am ] |
| Post subject: | Re: Manual Vacuum Hubs |
I'd only engage them when sitting still. The Jimny transfer has a syncro so when you put it into 4wd at speed it brings the front tailshaft and diff components up to speed before it locks the hubs. You could just put a switch inline with the wire from the 4wd switch on the transfer. That way putting it in 4wd would automatically lock the hubs and it would leave the whole computer system intact which is handy. Driving through some scrub I ripped one of the vacuum lines off. I immediately knew what the problem was (and indeed, that I had no 4wd) because of the flashing 4wd light. Your 4wd light would be totally accurate too, you wouldn't forget that you unlocked the hubs. |
| Author: | Seth2013 [ Wed Jan 21, 2015 2:26 pm ] |
thanks sideways hadn't thought of putting it inline, but seems like the logical thing to do. |
