Vehicle: Suzuki Sierra sj70 1995
Posted: Thu Jan 22, 2015 6:23 am
Hello all, Vehicle is a 1995 sj70 soft top Sierra My wipers stopped working suddenly, have checked all fuses and seems okay. When I try to turn the wipers on there is no action, no motor noise etc I have done a search and found a bit of info. I am trying to confirm if my wiper motor is shot or perhaps the switch on the stalk. I have folded down the windscreen and have access to the motor, after unplugging the motor I have found that I have 12v at the plug on the blue and yellow wire (which I believe is the main power wire) with the wipers turned both on and off, and 10v on 2 wires and 3v on the last. This changes slightly when turning wipers from hi to low etc I am a bit confused as to what this means and was hoping someone could run me through troubleshooting the problem? Thanks heaps Jesse
Users browsing this forum: Google [Bot] and 126 guests
