| g16b baleno to sj413 wiring harness photos https://auszookers.com/forum/viewtopic.php?f=5&t=49117 |
| Author: | Ash_SJ50Zuk [ Mon Jan 26, 2015 4:42 pm ] |
| Post subject: | g16b baleno to sj413 wiring harness photos |
Hi All, Currently doing a g16b sierra conversion. Part way into wiring, having a few doubts following diagrams ive seen. Anyone got any photos of a completed harness they could share, would just like to see if i'm on the right track and what i can expect for finished result. any input would be appreciated Cheers, Ash.. |
| Author: | J--A--C--K [ Thu Jan 29, 2015 8:00 pm ] |
| Post subject: | Re: g16b baleno to sj413 wiring harness photos |
There are a few photos around , the good tech section has a write up. And try putting it into search and select the rigs of auszookers , plenty of good build with photos of conversions. I'm just drawing a blank on any names with Beleano into 413. Gwagonsteve has pictures of his harness into a 410 lwb. It's called hedgepig . |
| Author: | suz_rolly [ Thu Jan 29, 2015 10:01 pm ] |
Photos won't help you if you explain what your problems are I'm sure someone on a here can help I have a vitara g16b if you need any photos I can get them for you but as for seeing the wiring it's all covered in the loom |
| Author: | Teracis [ Thu Jan 29, 2015 10:54 pm ] |
I'm pretty sure cairns zook and bluesuzy have write ups in good tech that will help you out. It's been so long I've forgotten where everything is around here and I haven't even started doing my wiring yet. |
| Author: | slowsierra [ Mon Feb 09, 2015 4:19 am ] |
Hi all I need some help. I few years ago I paid a lot of money for a well known Suzuki mechanic to supply and install a g16b coil pack baleno engine into my swb Sierra. I have never had a problem with how it ran but have now decided to put the engine into my lwb Sierra. After I removed the engine and wiring i thought it was odd how little wiring there was. All the motor wiring seems to be there, going to the fuse box and computer. But the only other wiring is a posite from the battery to the fuse box and the coil ing wire from the Sierra harness to the baleno and that's it. No vss no oil pressure no check engine light. What else is missing and wires should I be looking for? |
| Author: | slowsierra [ Thu Feb 12, 2015 4:11 pm ] |
Anyone? |
| Author: | Blkfxx [ Thu Feb 12, 2015 5:37 pm ] |
Perhaps some pics of the loom? |
