| Removal of front bump stops. Jimny https://auszookers.com/forum/viewtopic.php?f=5&t=49254 |
| Author: | Xtreme [ Fri Feb 06, 2015 10:59 am ] |
| Post subject: | Removal of front bump stops. Jimny |
I am making some 50mm spacers for my bump stops - the rear being easy to access and take off pose no problem, but can anyone tell me if you need to remove the front springs to remove the front bump stops? (recovering from an op and cant really get under there to look properly at the moment - just wanted to know if I can do it easily now or ill have to wait). Also do the front ones have a thread coming out of them with a nut? |
| Author: | mnemonix [ Fri Feb 06, 2015 11:24 am ] |
| Post subject: | Re: Removal of Front bump stops |
- Spring removal not required, at worst if you springs are heavily sagged you may need to jack the front of the car up slightly. If this were the case, your 50mm bump stop extension would not be possible to fit though. - Front bump stops are attached with m8x1.25 25mm bolts. The nuts are captive in the bump stop mount. |
| Author: | Xtreme [ Fri Feb 06, 2015 11:27 am ] |
cheers thanks |
| Author: | SierraDan [ Fri Feb 06, 2015 3:50 pm ] |
He's got a Jimny, Mark. |
| Author: | mnemonix [ Fri Feb 06, 2015 4:13 pm ] |
oh. So he does. Bwahaha. Sorry about that. Ignore my advice, talk to a hairdresser. |
| Author: | Xtreme [ Fri Feb 06, 2015 4:58 pm ] |
Any hairdressers out there know the answer? |
| Author: | coily96 [ Fri Feb 06, 2015 7:44 pm ] |
Not a hairdresser but ive cut hair before, im sure ive seen the Jimny front bumpstops to be tac welded in place inside the coil spring? Just put your head inside the wheel arch, top of the coil. |
| Author: | monley [ Sat Feb 07, 2015 1:49 pm ] |
| Post subject: | Re: Removal of front bump stops. Jimny |
They are just pushed in and held in place by a little rubber knob. Good luck getting them out in one peace and yes the springs will have to be removed IIRC |
