I recently replaced the timing belt tensioner, crank pulley and keyway.
When I replace the crankshaft sprocket inner belt guide, The rear guide spins on the shaft and makes a horrible noise. What is meant to be back there stopping this thing spinning on the shaft? If I can figure that out I'll put it all back together.
Users browsing this forum: Google [Bot] and 320 guests
