It is currently Fri Oct 23, 2026 11:39 pm
Vehicle: suzuki sierra
Post Posted: Tue Feb 17, 2015 4:11 pm
has anyone used uhmwpe tape between the leaf springs.were do you buy it from in Australia.and what thickness tape to use.thanks
Post Posted: Wed Feb 18, 2015 1:11 pm
so that's a no then
Post Posted: Wed Feb 18, 2015 1:18 pm
I had some leaves that had teflon tape or something between the leaves... it last about 3 offroad trips before flogging out and creating a heap of noise. Had to open up the packs and blast out the leftovers to make them quiet again.
Technology may have come further since then, but i'm a skeptic.
Post Posted: Thu Feb 19, 2015 6:02 am
My OME leaves had them.
They did wear out, afterwards I just used high pressure grease between leaves,
with a sand, clean and regrease every 3 years ish.
Vehicle: Suzuki SJ413
Post Posted: Thu Feb 19, 2015 8:00 pm
I have used a Teflon type tape in between my leafs before. I did find the ends wore out after a while but it helped stop sand and rust building up in between and i felt it rode a little softer as the friction between the leafs is reduced .
Here's a photo of the stuff I used , it didnt cost to much and had a sticky back.
Post Posted: Thu Feb 19, 2015 8:08 pm
That stuff looks way better than the small pads fitted to mine.
I thinks that would last a lot longer.
Users browsing this forum: Google [Bot] and 122 guests
