It is currently Sat Oct 24, 2026 8:29 pm
Vehicle: Suzuki Sierra
Post Posted: Wed Feb 18, 2015 8:05 pm
So I offically gave up trying to do the g16b loom mods because I cannot find a single wiring diagram (of the 9 variants i've looked at) that actually matches my vitara loom.
Anyone got contact details for this bloke: http://www.ebay.com.au/usr/killalux?_tr ... 7675.l2559
I've sent him a couple ebay messages but got crickets in reply
Or contact details for someone who might be able to do my loom for me (pref in Australia, also pref a workshop or someone with a reputation)
thanks in advance
Post Posted: Wed Feb 18, 2015 8:19 pm
Where abouts are you situated?
https://www.facebook.com/pages/Killa-Ku ... 85?fref=ts
0404811498
Post Posted: Wed Feb 18, 2015 8:34 pm
Ballarat, Vic. I'll post the loom out anywhere tho.
Post Posted: Wed Feb 18, 2015 8:41 pm
I should probably mention that I ripped the vitara intake manifold off and put a g13bb one on, but i just changed the sensors over from the vit mani.
Post Posted: Thu Feb 19, 2015 6:37 am
Because you are using the g13bb manifold plugs and sensors it wont line up with the length of the cabling and bundled loom.
As its on the other side of the intake now.
Also depends where your afm goes.
so you would have to modify one done by someone else anyway.
Where in Ballarat are you?
I can have a look at things for you, if you want to keep trying
Post Posted: Thu Feb 19, 2015 10:53 am
Brown Hill, send me a pm.
Post Posted: Thu Feb 19, 2015 3:39 pm
He's offering his services, call me old school but wouldn't it be the right thing to do & contact him... :?
Post Posted: Thu Feb 19, 2015 7:23 pm
He sent me his details and I sent him a text. :)
Post Posted: Mon Feb 23, 2015 5:10 pm
You have an early g16b loom
This will be helpful
http://www.suzukiinfo.com/vitara/vitara ... 1_mpfi.pdf
This is the bare minimum of what you need to run
http://www.suzukiinfo.com/vitara/wiring ... g16a-b.pdf
The german variant will be quite close, I had a few wires different, but if you trace it all and work it all out its pretty easy
http://www.suzukiinfo.com/vitara/vitara ... iagram.pdf
There's a lot of links here
Its easy to strip the sierra and vit looms back, work out what you need and what you dont.
You already have it unbundled, so start labelling and stripping out the excess.
Hardest part is getting the routing, lengths and bundling correct etc (especially if things change later)
Its advisable to keep joins and sections you have messed with in the one easy to locate and access spot.
I prefer the plug at sierra loom behind the glovebox. Also ideal spot to mount the ecu
Users browsing this forum: No registered users and 289 guests
