| sierra disc brakes https://auszookers.com/forum/viewtopic.php?f=5&t=49442 |
| Author: | kdalton [ Sat Feb 28, 2015 2:30 pm ] |
| Post subject: | sierra disc brakes |
any photos or information of how to disassemble disc brakes to refurbish or overhaul disc brakes would be very gratefull.for a sierra.my left hand front brake is dragging.thanks |
| Author: | alien [ Sat Feb 28, 2015 2:38 pm ] |
| Post subject: | Re: sierra disc brakes |
Wheel off, undo the 2 caliper bolts and away you go? |
| Author: | Xr6_matt [ Sat Feb 28, 2015 2:39 pm ] |
Brakes are a pretty important part of the vehicle, if you don't really know what you're doing I dont think you should be playing around down there.. |
| Author: | alien [ Sat Feb 28, 2015 3:47 pm ] |
Xr6_matt wrote: if you don't really know what you're doing I dont think you should be playing around down there.. I've heard that one before.. |
| Author: | Xr6_matt [ Sat Feb 28, 2015 3:57 pm ] |
alien wrote: Xr6_matt wrote: if you don't really know what you're doing I dont think you should be playing around down there.. I've heard that one before.. First time for everything though aye |
| Author: | flymaster [ Sat Feb 28, 2015 9:09 pm ] |
Go to Low Range Offroad's site and in the instructional page there's info on doing most jobs on Suzies. |
| Author: | whincup [ Sat Feb 28, 2015 10:53 pm ] |
get a service manual from supercheap. best $40 i ever spent. everyones gotta learn at some point, but with critical stuff like brakes, best to have someone who knows what they're doing to teach you first time round. its very simple once you know what your doing... |
| Author: | AckerDackerly [ Sun Mar 01, 2015 3:28 am ] |
whincup wrote: get a service manual from supercheap. best $40 i ever spent. everyones gotta learn at some point, but with critical stuff like brakes, best to have someone who knows what they're doing to teach you first time round. its very simple once you know what your doing... What alien sez! Wheel off, undo the 2 caliper bolts and away you go? The '88 SJ413 FSM is available for download at Ack's FAQ - which should be a cheap and good guide. I have removed the calipers a number of times to install pads and to refurbish the knuckle joint. The touchy part is the pad clips and the caliper slides - which should be complete with rubber boots and proper lubrication so they do not bind. These items should be available at the local factors/car parts store. Use a metal coat hanger bent into a hook to hang the caliper assembly off the upper shock mount to keep from damaging the hydraulic line. I hope that this helps! |
