It is currently Sat Oct 24, 2026 1:21 pm
Post Posted: Thu Mar 05, 2015 8:33 pm
Does anyone know if Sierra and vitara clutch cables are the same? Or close enough to be interchangeable.
Post Posted: Thu Mar 05, 2015 10:36 pm
Are after vitara one if so got one here $15
Post Posted: Fri Mar 06, 2015 5:37 am
The early Vitara one is similar, about the same length but the adjustment range at the gearbox is a bit different
I used a Sierra one on my vit with a flipped bracket at the box end for years
Post Posted: Fri Mar 06, 2015 9:28 pm
Thanks guys. Doug I'll be in touch once I have a closer look at the problem. Still not sure the cable is the problem, but hoping it is!
Post Posted: Sat Mar 07, 2015 6:13 am
if its spongy and not working properly when its worm the cable is probably soft where it goes past the bottom hose
Also the firewall cracks
Users browsing this forum: Google [Bot] and 89 guests
