| Sierra/vitara clutch cables https://auszookers.com/forum/viewtopic.php?f=5&t=49482 |
| Author: | mrw82 [ Thu Mar 05, 2015 8:33 pm ] |
| Post subject: | Sierra/vitara clutch cables |
Does anyone know if Sierra and vitara clutch cables are the same? Or close enough to be interchangeable. |
| Author: | dougies_tx5turbo [ Thu Mar 05, 2015 10:36 pm ] |
| Post subject: | Re: Sierra/vitara clutch cables |
Are after vitara one if so got one here $15 |
| Author: | royce [ Fri Mar 06, 2015 5:37 am ] |
The early Vitara one is similar, about the same length but the adjustment range at the gearbox is a bit different I used a Sierra one on my vit with a flipped bracket at the box end for years |
| Author: | mrw82 [ Fri Mar 06, 2015 9:28 pm ] |
Thanks guys. Doug I'll be in touch once I have a closer look at the problem. Still not sure the cable is the problem, but hoping it is! |
| Author: | royce [ Sat Mar 07, 2015 6:13 am ] |
if its spongy and not working properly when its worm the cable is probably soft where it goes past the bottom hose Also the firewall cracks |
