| SJ80 Front left oil leak https://auszookers.com/forum/viewtopic.php?f=5&t=49515 |
| Author: | Tonner [ Mon Mar 09, 2015 5:59 pm ] |
| Post subject: | SJ80 Front left oil leak |
I have diif oil all over the LF rim so Im assuming its the axel seal, do I need to strip the whole steering knuckle and hub or can I remove the axel and hub whole and just replace the seal? |
| Author: | qwerty123 [ Tue Mar 10, 2015 3:46 pm ] |
| Post subject: | Re: SJ80 Front left oil leak |
no need to pull the hub apart. just unbolt the knuckle from the hub. 4 bolts behind disk rotor and the hub comes off along with the CV and Axle all connected buy a tub of grease and prepare to get dirty also i recommend you replace the scraper seal and felts while your at it |
| Author: | Tonner [ Tue Mar 10, 2015 9:02 pm ] |
Cheers qwerty123,.....the knuckle seals and felt have just been done recently (before I bought the vehicle) Im guessing the previous owner didn't do the axle seal while he was at it unfortunately. Im thinking I might as well do the lot and get it over and done with. |
