It is currently Sun Oct 25, 2026 9:54 pm
Vehicle: 1997 SWB Vitara
Post Posted: Mon Mar 02, 2015 9:36 am
Hi guys, I have a 1997 Vitara SWB G16B with no A/C or P/S and just bought a 1990 Vitara SWB G16A that HAS A/C and P/S because it had a flexiglass canopy on it which is worth more than the car itself and I got the whole car for a bargain. Anyways I've been looking at it wanting to put the power steering into the G16B but looking at it it looks like the exhaust manifold will be in the way of where the P/S pump would mount. Has anybody else done this? Can someone tell me what needs to be done to fit it and will I need anything apart from whats on the car? The G16B has a 2 pulley harmonic balancer so theres a place for an extra belt.
Also has anybody converted their non A/C to A/C? I know the G16A systems need to be converted to R134A but I just wanna know if they bolt up alright to the G16B and under the dash? Mine looks like it has the 2.0L dash with the 2 glove compartments.
Any help would be appreciated.
Thanks
Vehicle: SWB Vitara
Post Posted: Mon Mar 02, 2015 6:46 pm
We put p/s onto our non-p/s 1996 Vitara. Mechanic did it for us, bolt on as I understand it. It didn't foul with the exhaust, ours was a set of extractors though. But I imagine they were the same.
Pretty sure the steering shaft was swapped as well. At the very least we no longer needed the extension spacers we had in there for the body lift.
Post Posted: Mon Mar 02, 2015 7:42 pm
Thanks for your reply mate. So pretty much swap the boxes & shafts over and bolt the pump and reservoir on and bobs your uncle?
Looks like the pump on yours is mounted where the A/C compressor bolts onto the G16A? On the g16b if mounting where the pump is positioned on the g16a (next to exhaust manifold) the middle bolt hole is taken up by the last bolt on the exhaust manifold. it obviously works on yours nonetheless! Thanks
Post Posted: Mon Mar 02, 2015 8:36 pm
Tried a power steer pump bracket from a g16a?
Post Posted: Mon Mar 02, 2015 9:29 pm
I haven't tried fitting it yet. Just working out what's involved and what's needed etc
Just wanted to see if anybody's done the same thing
Vehicle: 1996 zook with lift and tyres
Post Posted: Thu Mar 05, 2015 7:53 pm
ecco, give me a buzz if you get stuck, ive done 2 in the last few weeks. i may even be able to help with brackets. i use the ones off my old 1.3 engines which work fine.
Post Posted: Sat Mar 07, 2015 10:44 am
I went back and had another look, the a/c compressor is on top and p/s pump on the bottom so my bad lol.
Has anyone used the a/c from a G16A in a G16B?
Thanks Diesel! :)
Vehicle: 88 Vitara G16A
Post Posted: Sat Mar 07, 2015 10:03 pm
I'm sorry to just jump in on this thread but perhaps helping me could also help the OP. I've bought the parts for a G16A PS conversion for my 88 Vitara without power steering. any chance someone has a picture of where the PS hoses run and how they secure/clamp to the engine or body? I've never seen it in person nor saw the donor car.
Thanks in advance
Vehicle: SWB Vitara
Post Posted: Sun Mar 08, 2015 9:11 am
Thanks in advance
On mine, they run along the front of the front cross member. You can see them in the photo below in the yawning gap between winch bar and skid plate.
I really should do a bash plate - they really are quite exposed there.
Post Posted: Sun Mar 15, 2015 8:12 am
Thanks in advance
Hey mate I'll try get some pics today if I can of how the power steering is run on my G16A, lucky I havent pulled it out yet. Like Pico said the hoses do run across the front crossmember.
Users browsing this forum: Google [Bot], Google Adsense [Bot] and 103 guests
