Page 1 of 1
[ 6 posts ] |
Print view
Previous topic | Next topic
| Author |
Message |
finbar
Vehicle: holden drover/suzuki sierra
 Posted: Thu Mar 12, 2015 3:13 pm |
Gday Just bought the vehicle 1985 high top double badged drover /sierra. Its got 2" lift with EFS leaf springs and shocks , 31" muddies on 15x7 rims . Now the fuel consumtion is around 40 litres per 100kms!!!! Crazy stuff, it starts first go generally but if it doesnt it drowns and takes a while to start . Stinks of fuel all the time and strong fuel smell from exhaust . It drowns under medium acceleration also. Had a good look over /under the vehicle and no fuel leaks , the mechanism for the accelator cable to carby stcks a bit so it doesnt idle down and sits around 1000-1250rpm at idle. Lubed it no difference. Played with the idle speed screw ..no diff. Yet to go further than this....So anyone had any experience with this sort of thing and sny possible solutions or things to try out, Im handy i just need direction. Thanks ...cool site btw
alien
 Posted: Thu Mar 12, 2015 3:24 pm |
Choke is busted and stuck on...
Plus if you're running 31s and no gearing you'll be revving quite low which won't help (they like to rev).
Also keep in mind a 31" tyre is about 20% larger than factory, so 100km/hr on the speedo could infact be 120km/hr and likewise on the odometer.
MrRocky
Joined: Thu Dec 17, 2009 10:30 pm Posts: 4731 Location: perth
 Posted: Thu Mar 12, 2015 4:12 pm |
Check for fuel leak 13-15 ltrs per 100km should be about the max u should use
finbar
 Posted: Thu Mar 12, 2015 6:33 pm |
Thanks, had the gear reduction installed before i got it ,speedo is out 2km/ hr at speed of 100km/hr . I will have a look at the choke ,sounds likely considering what its doing ,any special way to sort it Cheers
alien
 Posted: Thu Mar 12, 2015 7:36 pm |
finbar
 Posted: Fri Mar 13, 2015 7:57 am |
Thanks Alien will look into it
Page 1 of 1
[ 6 posts ] |
Users browsing this forum: No registered users and 182 guests
