It is currently Tue Oct 27, 2026 2:11 am
Vehicle: 02 Suzuki Jimny
Post Posted: Tue Mar 10, 2015 7:26 pm
Hey Guys,
The other day i filled up a new tank of fuel at United. Just a little ways down the road my jimny started realllly struggling under acceleration. I have to really ride the clutch to get going and on the highway it was flatout struggling to do 80k/hr. Engine light came on periodically.
Here is a video so you can get in idea what i'm talking about.
http://youtu.be/wCLI1r2eS2w
Please help!
Cheers TF
Vehicle: 2000 Jimny
Post Posted: Wed Mar 11, 2015 7:21 pm
sounds like limp mode came on, i've had it happen also.
my jimny struggles on initial acceleration all the time, has a real 'flat spot' on initial take off. if i fill with premium unleaded it's REALLY bad, actually dangerous as i pull away from intersections.
can't help you with the cause though, i had thought it may have been a blocked catalytic converter but i temporarily dropped that on the weekend & it made zero difference.
Vehicle: 2000 Jimny
Post Posted: Wed Mar 11, 2015 7:22 pm
double post, i also swapped out my O2 sensor & that didn't fix it either.
Post Posted: Wed Mar 11, 2015 7:25 pm
Interesting. My initial thought was something blocking the fuel filter. But I wonder now if there some sort of issue with the EGR?
TF
Vehicle: 2000 Jimny
Post Posted: Wed Mar 11, 2015 7:34 pm
wait for one of the more knowledgable guys to post up some ideas as i have nfi what's wrong with my car without trying to diagnose yours lol.
have you chucked in another tank of fuel just in case it was a dodgy batch ?
Platinum Supporter
Platinum Supporter
Vehicle: 2010 jimny
Post Posted: Wed Mar 11, 2015 11:40 pm
Could be some water or dirt blocking you're filter.
could be you grabed e85 by mistake?
Post Posted: Thu Mar 12, 2015 4:43 pm
I thought that too Jezz but looking at the manual the filter is a PITA to get out. Looks like you have to drop the whole fuel tank.
I Did fill up with e85. but have always done that and it's been fine. Maybe i hit a bad batch :/
TF
Vehicle: Coily
Post Posted: Thu Mar 12, 2015 9:48 pm
You cant run your jimny on E85
A simple fact
i seriously doubt you have been running E85 prior to this and had no problem.
Post Posted: Thu Mar 12, 2015 9:51 pm
e85 is just the ethanol blend at United right?
Have been for years.
TF
Post Posted: Thu Mar 12, 2015 9:54 pm
Wait wait. my bad... i've been using E10
Dunno the difference, but i've been filling up with E10 for ages.
TF
Vehicle: Coily
Post Posted: Thu Mar 12, 2015 10:11 pm
yeah e10 shouldn't be any issue
i bet you accidentally put e85 in thinking it was e10
considering this started right after u filled up,
if you did i would suggest pumping as much unleaded in the tank as possible to dilute the ethanol.
Post Posted: Thu Mar 12, 2015 10:15 pm
United doesn't have E85 though do they?
I might just dump out some fuel anyways and pump unleaded in to see if it makes a difference.
TF
Vehicle: Coily
Post Posted: Thu Mar 12, 2015 10:25 pm
united are the only ones with e85 as far as I'm aware.
the handle is orange
e85 really confuses the ECU and will trip it into limp mode
done it before topped of with 91 and it was fine after that
lesson learnt my old golf could handle up to about a 50% ethanol content before going haywire
Post Posted: Fri Mar 13, 2015 6:55 am
Interesting. Thanks!
TF
Vehicle: Which one?
Post Posted: Fri Mar 13, 2015 7:14 am
E85 pumps should really have the same bowser lockouts that many diesel pumps have, with a warning on them you have to push before it will release the handle.
Platinum Supporter
Platinum Supporter
Vehicle: 2010 jimny
Post Posted: Fri Mar 13, 2015 10:35 am
or, we could read the things?
Vehicle: Which one?
Post Posted: Fri Mar 13, 2015 10:38 am
I think this thread proves that no, no we can't.
Platinum Supporter
Platinum Supporter
Vehicle: 2010 jimny
Post Posted: Fri Mar 13, 2015 10:59 am
rubber hoses on fuel system likely on the way out, normal fuel systems generally have to be modified to resist the corrosion ethanol causes at those concentrations.
as suzuki hasnt changed the jimnys much, at all, ever, id say be on the lookout for other fuel system problems
Post Posted: Fri Mar 13, 2015 11:59 am
I've seen what E85 & unleaded does when mixed... no way in hell will I ever fill a regular car with it.
Something built & tuned for e85 is a different story tho.
Post Posted: Sat Mar 14, 2015 4:42 pm
i got 40l's of fuel i gotta try work out the best way to get out of the tank.
got any ideas?
TF
Vehicle: Suzuki Jimny 2009
Post Posted: Sat Mar 14, 2015 5:45 pm
Can you siphon it out or does the filler tube have an anti siphon device? Try pushing a garden hose down the filler cap. Another way is to use the fuel pump to pump it out into jerry cans by breaking the fuel line and extending it with a hose.
Post Posted: Sat Mar 14, 2015 5:58 pm
It has an anti siphon device.
I think I'll have to pump it straight out of the fuel line
TF
Post Posted: Sun Mar 15, 2015 10:54 am
Have we established that Total_Filth put E85 in? I didn't think that was clear.
Users browsing this forum: Google [Bot] and 311 guests
