Gday all Recently I reconditioned the motor in my '95 lab vitara. All's good with it (much stronger, better economy & uses no oil now) except for an erratic idle. Sometimes it will idle properly at around 800rpm, other times it will drop to well below 500rpm & slowly work its way back to 800rpm. The a/c does raise the revs to about 1000rpm. When starting the car from cold the revs never go above 1000rpm. I have changed the IAC unit & when I test it by putting 12v across it it does open up. Has anyone else had this problem & can point me to a fix. I'm thinking its a faulty sensor or possibly coolant flow to IAC? Thanks Redvitara
Users browsing this forum: No registered users and 207 guests
