It is currently Sat Oct 24, 2026 9:43 pm
Post new topic Reply to topic  [ 34 posts ]  Go to page 1, 2  Next
Vehicle: 95 maruti trayback
Post Posted: Tue Mar 17, 2015 6:37 pm
How many kms is everyone getting to a tank in there 2.5l v6 grand vitaras? Cheers 8)
Post Posted: Wed Mar 18, 2015 6:43 am
10.5lt per 100ks
Post Posted: Wed Mar 18, 2015 4:03 pm
geeez thats alot better than mine. have you got any mods?
Post Posted: Wed Mar 18, 2015 5:00 pm
No - Just keep your foot off the brake as much as possible and you will get good mileage out of most cars.
Post Posted: Wed Mar 18, 2015 5:10 pm
You probably won't get many replies mate as its well known that they suck juice like there is no tomorrow.
Stock standard they aren't too bad as per Tony's figure above. Soon as you start modifying them with anything that screws with the aerodynamics (bigger/wider tyres, more lift, roof racks, spotties, bullbar, awning etc etc) economy goes out the window.
I'm getting anywhere from 300 - 450km from a tank depending on what I'm doing (on-road/offroad/thrashing it or driving sedately etc). I'd need to be driving down hill an awful lot with a gale force wind behind me to get anything approaching 500km to the tank.
Post Posted: Wed Mar 18, 2015 7:11 pm
Yep they drink like no tomorrow if modded. I'm weighing up wether i fix my oil leaks or just get rid of it!
Vehicle: 2003 V6 Grand Vitara (SQ625)
Post Posted: Wed Mar 18, 2015 8:39 pm
Same
http://www.auszookers.com/forum/viewtopic.php?t=36934
Post Posted: Wed Mar 18, 2015 9:16 pm
paging macdaddy & his fuel generating GV
Post Posted: Wed Mar 18, 2015 9:28 pm
Ok thanks guys I've been getting about 350-400kms out of a tank so I guess that's about average. Cheers
Post Posted: Thu Mar 19, 2015 9:13 am
Fix it :)
I pissed off the car gods when I bought a BT50 and it cost me dearly. The suzis may like a drink themselves but at least they won't drive you too drink.
Post Posted: Thu Mar 19, 2015 11:12 am
Do you guys just use 91? Ir do you run more premium stuff?
Vehicle: LJ80
Post Posted: Thu Mar 19, 2015 11:26 am
my young fella reckons he's getting 10l to 100klm .
2.5 man on 98 about 85% hwy driving ( 2" lift and a low alloy bar
Vehicle: 04 Grand Vitara, 2.5L, V6
Post Posted: Tue Mar 24, 2015 3:51 pm
I find a get better economy on 98 and its not happy on 91 wouldn't use less than 95 if possible. If you do things like snorkle, exhaust, O2 sensors, air filter, flush fuel system, headers everything todo with fuel and air delivery and exit you can get 10L/100km with a modded GV. Fully modded to excess I get around 12L/100km
Post Posted: Tue Mar 24, 2015 4:40 pm
Yeah I've been running 95 but might try 98 I've got plans for an exhaust system and extractors in the future so hopefully I can get better fuel economy. As for air I've got the snorkel with a k&n filter so that's really the best I can do with that?
Post Posted: Tue Mar 24, 2015 6:10 pm
yea thats about it. Snorkel, high flow air filter, good spark plugs, 98 oct fuel, new O2 sensors, Extractors, high flow cat, 2.25/2.5in exhaust, then diff gears to match tyres. thats about it as far as mods to attempt to improve economy. then basic oil and filter changes also help.
Post Posted: Tue Mar 24, 2015 6:22 pm
Wheres the best place to find diff gears and what ratio would I need for a manual?
Post Posted: Tue Mar 24, 2015 6:27 pm
depends what size tyre you are running. if you want lower low and lower than stock you'll need 5.12s or for a mild change to match up to a 31 go for 4.8s out of an auto gv. your current will be 4.3. check people wrecking gvs for 4.8s or vits for 5.12s. you will need 12 bolt rear crown wheel. search on here it's all been done before
Post Posted: Tue Mar 24, 2015 6:37 pm
Can you change the different ranges like high instead of low or does changing the crown affect both high and low?
Post Posted: Tue Mar 24, 2015 6:56 pm
ring and pinion affect the final drive regardless. if you want to change only high or low it would need to be in the transfer case.
Post Posted: Wed Mar 25, 2015 4:58 pm
What Sco-tie Said, but also check out this pages to find a solution that works for your desired diff/tyre combo, the available GV ratios are all on the pages.
http://suzuki-grandvitara.info/cms/comp ... Itemid,67/
http://suzuki-grandvitara.info/cms/cont ... y/7/34/64/
Post Posted: Wed Mar 25, 2015 5:22 pm
Interesting link, first time I've seen that ratios info. Makes we wish I had really waited a bit longer and found an 03 model XL7 however. 4.3x diff ratios for the auto models combined with the 5spd trans would be glorious for running bigger rubber. I'd almost put up with the munted front headlights for that :lol:
Post Posted: Thu Mar 26, 2015 1:18 pm
Just put a bull bar (ECB ali one) and spotlights on and today did our usual shopping trip to town - 160ks total 110ks flat bitumen the rest a mixture of dirt, gravel and rough track - air con on one way - 16.5 lts Same as before the bull bar.
Post Posted: Thu Apr 09, 2015 9:34 pm
Will I be alright running 31s with stock gearing? It's only going to be for offroad this winter so I'm not worried about power loss onroad
Post Posted: Thu Apr 09, 2015 10:00 pm
Yes you will be fine Im guessing they are going to be 245/75/16 so 30.5in plenty have done it on stock gearing. It will be easier if you have a manual for on road and easier in an auto off road. otherwise you'll need some clutch slippage.
Post Posted: Fri Apr 10, 2015 2:08 pm
What about 235 85 16? (31.7")
Post Posted: Fri Apr 10, 2015 2:56 pm
Firstly good luck fitting them. Not sure what your set up has bit a BL is needed and offset rims ri clear the chassis and cross member then you will break lots. And then I would definitely recommend gears
Post Posted: Fri Apr 10, 2015 3:04 pm
Ok I'll just stick with the 245 75 then. I'm running 2" lift and installing 1" body soon.
Post Posted: Fri Apr 10, 2015 3:32 pm
Don't bother with a 1in bl.
Post Posted: Fri Apr 10, 2015 3:36 pm
Whys that?
Post Posted: Fri Apr 10, 2015 5:45 pm
Don't need a BL to fit 245/75/16s to the GV.
add some coil spacers and extended bumpstops and just do some panel beating of the inner guards.
Users browsing this forum: No registered users and 174 guests
