It is currently Sat Oct 24, 2026 2:20 pm
Vehicle: Drover pickup turk
Post Posted: Sat Mar 28, 2015 12:15 pm
Needing to replace the windscreen in my WT tintop and I was looking at how it was held in the other day and comparing it to my utes windscreen.
Ute has a rubber seal that appears to go either side of windscreen, So it holds the windscreen in and seals at the same time, Looks factory.
The tintop on the other hand has a rubber seal on the outside but on the inside you can see windscreen silicone around the edge, also has pinchweld around the frame (whereas the ute seal covers the frame). Is this factory or something somebody (a shop perhaps?) done when the screen might have been replaced?
I did do a search and all results I looked at suggested rubber seal like my ute has, Having to rope it in to install.
I like the tuna here
Vehicle: LJ50V 2 stroke
Post Posted: Sat Mar 28, 2015 2:52 pm
not all my 92 tin top is bonded in, no rubber seal
Post Posted: Sat Mar 28, 2015 5:07 pm
Is that Jinxy? If so, I reckon it had a Coil screen fitted at some point. They are bonded in.
Post Posted: Sun Mar 29, 2015 7:01 pm
Yep ALL sierras except coily use the same screen and rubber.
Coily has no rubber and uses a slightly larger screen that is glued in.
Users browsing this forum: Google [Bot] and 168 guests
