It is currently Fri Oct 23, 2026 7:04 am
Post Posted: Tue Mar 24, 2015 4:57 pm
Trying to get some firm facts on what number of teeth are on the various sensor rings of GVs and Jimnys.
From what I can tell so far:
jimny rear is 38 teeth
GV front is 53 teeth
Post Posted: Wed Mar 25, 2015 11:05 am
also does any one know if the number of teeth on the rings has any great bearing on how the abs works.
i.e if I went from a 38 tooth to a 45 tooth would it throw errors?
Vehicle: 91 Tin Top
Post Posted: Wed Mar 25, 2015 11:33 am
According to the manual; the ABS can throw alarms just by driving on sand or mud and spinning the wheels.
By that I would assume changing the number of teeth could cause issues.
Nothing in there about number of teeth front or back, but it's pretty clear in this pic that they are much bigger in the front.
Post Posted: Wed Mar 25, 2015 11:38 am
they are bigger. but they also have more teeth front to back.
so that says to me that the difference in diameter equates to the wheels spinning at different speeds and thus pulsing at the same speeds?
Vehicle: 91 Tin Top
Post Posted: Wed Mar 25, 2015 12:56 pm
One would ASSUME that your logic is correct and there would be more teeth on the bigger rings to give the same gaps for each sensor.
But like they say, assumption is usually the mother of all fuck ups. :)
Post Posted: Wed Mar 25, 2015 2:38 pm
or maybe its to do with brake bias to the front. arrgghh annoying
Post Posted: Wed Mar 25, 2015 2:57 pm
If you place a 38t gear on top of a 53t gear there's going to be very few teeth that directly line up (exactly 100%) - spinning them at the same speed the difference would remain. The only thing that would affect it is the rolling diameter of the tyre - a GV has a larger wheel/tyre combo than the jimny.
Base Model GV comes with a 28.4" Tyre
Upper Model GVs are a 30.4" Tyre
Jimny is 26"
There's clearly a margin for error though - if the GV runs a 7% larger tyre between model specs. One would assume suzuki don't update the software between these models? Although that likely also means the speedos are out 7% between models too.
Post Posted: Wed Mar 25, 2015 3:15 pm
they run different amount of teeth front to rear.
Post Posted: Wed Mar 25, 2015 4:08 pm
If you plugged the pulse data into a computer though it'd work out the difference pretty easily though? It could be to do with available space on the rear / front that influences the size difference rather than any brake bias. Brake bias would be done by the computer knowing if a wheel has stopped or not. You wouldn't limit how often it's pulsed as you'd want to have the quickest reaction time possible.
Post Posted: Wed Mar 25, 2015 4:30 pm
What are you trying to achieve?
Post Posted: Wed Mar 25, 2015 4:33 pm
im looking at how the abs works for floaters.
I don't want to have to run the normal ring that presses onto the axle shaft if I can help it.
thus running the front hubs and rings on the rear would be ideal
I have seen some pics where job had done this design on his but im not convinced it is a good idea.
Post Posted: Wed Mar 25, 2015 4:36 pm
the problem as I see it is if the computer is smart enough to freak out if the wheels are turning at different speeds, then making the sensor ring on the back bigger than standard will throw an error light and do god knows what to the brakes
Vehicle: 91 Tin Top
Post Posted: Wed Mar 25, 2015 6:53 pm
I figured you where working in something that might interest me soon enough. ;)
I went and had a look at our Jimny when the misses came home from work.
If it was as easy as ripping the wheel off and counting the teeth for you I would have. But it's not......
Post Posted: Wed Mar 25, 2015 7:30 pm
Yeah the ring sits behind the disk rotor
Vehicle: Suzuki Jimny 2009
Post Posted: Wed Mar 25, 2015 7:44 pm
Tanshi
I looked at this a while ago when I was considering a full floater rear and concluded that the number of teeth is probably not important and the ABS computer probably just compares the rates between both rear wheels. However, my concern was related to the brake proportioning and how the ABS would respond to a different rear brake cylinder type and pressure. I never got a clear answer to this one so if you do get this working I would be most interested in your findings.
Mike
Post Posted: Wed Mar 25, 2015 10:57 pm
^^ That's a fair point - however it could affect the aggressiveness of the ABS - ie: If the system is picking up a fast pulse it may do faster pulses of the ABS (ie: it knows you're going faster so wouldn't want the wheels to skid for a long distance), where as at slower speeds it'd be able to brake harder for longer to stop quicker??? I'm just guessing... maybe someone can find some gravel and test it out at different speeds to see if it pulses the brakes differently at different speeds?
Vehicle: 91 Tin Top
Post Posted: Thu Mar 26, 2015 5:59 am
I've had the ABS working a few times at high and low speeds on different surfaces. It always feels the same under foot.
I have a theory about safety features like air bags and ABS in budget cars such as Jimnys.
And I really don't believe they are as advanced as you are suggesting there alien.
I believe it's more like the sensor works within set parameters, once it goes outside of those the computer activates and pulses at a set rate to 'help' stop the brakes from locking up.
More advanced modern cars may have more advanced or intelligent ABS systems. But we're talking about a 15 year old car that they've slapped some extra things on to meet the safety rules of the time so they can keep selling them.
Post Posted: Thu Mar 26, 2015 7:21 am
I doubt the proportioning thing would be an issue. You would use an adjustable prop valve as you do on a sierra and the abs wouldn't know any different
I guess I need to find a guinea pig to test it
Post Posted: Thu Mar 26, 2015 8:47 am
Proportioning should be redundant with 4wheel antilock. I don't believe any car with 4wheel antilock runs a proportioning valve- the abs does that job more effectively than a prop valve could.
Post Posted: Thu Mar 26, 2015 8:52 am
Fair enough I guess that's true Steve.
I have just spoken to Joeblow. He says the tooth count is irrelevant as the computer only uses it to determine if the wheel is turning or not.
As he has don't the ABS before i'll trust his judgement.
Looks like it should be pretty easy to do these now.
Vehicle: 91 tin top
Post Posted: Thu Mar 26, 2015 8:58 am
All the abs sensors do is measure individual wheel speed by modulating the pulse width of the signal sent back to the abs brain. Ie, if it came with 53teeth, the computer will have a hissy fit if it is seeing a signal from a different number of teeth which will mimic a differing wheel speed. The overall size of the tone wheel is just for packaging, its the teeth count that matters. So if a car comes with 2 different teeth counts, then the computer is programmed to figure out the wheel speeds based off the differing counts.
Post Posted: Thu Mar 26, 2015 9:35 am
and as I said above. the tooth count doesn't matter in the GV or the JIMNY as tested and proven by Jowblow
Platinum Supporter
Platinum Supporter
Vehicle: 2010 jimny
Post Posted: Thu Mar 26, 2015 10:29 am
hyjack: if its a problem, could it be corrected with a linear frequency modulator to take frequency B and fudge it back to frequency A?
Post Posted: Thu Mar 26, 2015 10:36 am
guess that's possible, and I know just the guy who could do it.
Platinum Supporter
Platinum Supporter
Vehicle: 2010 jimny
Post Posted: Thu Mar 26, 2015 10:56 am
actually that's probably what the jcar kit does for the speedo for 40 bucks... http://www.jaycar.com.au/Automotive-%26 ... E/p/AA0376
Post Posted: Sat Mar 28, 2015 10:16 pm
FWIW, here are some pics of the abs sensor rings for the rear axle and the front hub from a 2004 GV, Back to front are quite different in design...
Post Posted: Mon Mar 30, 2015 12:46 am
If you have too many teeth the I suspect the ABS computer will throw an error if it thinks its doing 200mph and the ABS won't work properly at low speeds if there aren't enough teeth.
Post Posted: Mon Mar 30, 2015 8:59 am
Sezed? any chance you counted the teeth?
Post Posted: Wed Apr 01, 2015 7:42 pm
Nope, but I can pull them out tomorrow and have another look...
Users browsing this forum: No registered users and 140 guests
