It is currently Sat Oct 24, 2026 11:15 am
Vehicle: Sierra Ute & Tintop
Post Posted: Mon Apr 13, 2015 10:56 pm
I'm looking to relocate the battery in my sierra to help with weight distribution and while im at it i thought id upgrade to something a bit more powerful as I've just installed a winch and EL falcon alternator.
What's people suggestions on both battery type and where to put it?
It's a 92 SWB soft top that's been lengthened and chopped into a ute by the way.
Cal
Vehicle: Suzuki Jimny 2013
Post Posted: Tue Apr 14, 2015 7:02 am
Have you considered a dual battery setup?
Post Posted: Tue Apr 14, 2015 8:04 am
Optima d34 under the passenger seat.
The weight, complexity, cost and unreliability of a dual battery system isn't required.
Post Posted: Tue Apr 14, 2015 8:48 am
+1 on d34.
I wouldn't buy one from any of the big car parts stores,
I've had good dealings with kpd4x4 and 4wd products on eBay
Post Posted: Tue Apr 14, 2015 9:15 am
X2 for KPD
Post Posted: Tue Apr 14, 2015 10:21 am
D34
Vehicle: Suzuki Jimny 2009
Post Posted: Tue Apr 14, 2015 9:49 pm
Not sure KPD still deals with Optimas?
Post Posted: Tue Apr 14, 2015 9:59 pm
I'm hoping to avoid a dual battery setup for these exact reasons.
I'll look into the D34. I wouldn't think it would fit under a seat?
Post Posted: Wed Apr 15, 2015 5:25 am
Floor needs to be cut to drop the battery through. Been done on heaps of cars.
Post Posted: Wed Apr 15, 2015 11:55 am
I run dual batts for my engle ect...
770 cranking amps big euro batt.
Got about 5mm clearance
$120 for redarc kit
Post Posted: Wed Apr 15, 2015 2:26 pm
Cheers guys.
KPD4x4 still do Optima Batteries too, I've just ordered a D34.
I'll wait until it arrives and then start playing around with locations.
I considered moving it to the left guard MrRocky but I have the older model ARB compressor which is already taking up that real estate.
Vehicle: '94 suzuki maruti
Post Posted: Sat Apr 18, 2015 8:03 am
complexity? unreliability? no offence but thats a load of crap. they're quite basic, and maybe a few hundred dollars for a good quality setup including battery. small price for people who need it. and in 3 years im yet to experience this unreliability. obviously not what the OP is chasing though
Vehicle: Vitara SE416
Post Posted: Sat Apr 18, 2015 10:37 pm
I have a friend with acid burns to the back of their legs from an exploding battery under the passenger seat. I wouldn't do it as you need to have the battery box vented which means acid will escape of it explodes. The under seat battery was a factory fitted job on a police car, not a backyard job.
Post Posted: Sun Apr 19, 2015 10:53 am
The battery box needs to be vented to outside not into the cabin.
a dual batt is only needed to run a fridge and should really be charged by a dc to dc charger. All other isolators really should be the same battery type age etc so they charge equally.
I just run a big batt swich that I can choose what combination of batt I want connected. No electronics to fail and drain power.
Post Posted: Wed Apr 22, 2015 5:37 pm
I'll stand by my opinions Whincup. I have seen enough dual battery systems die and wipe out one battery or the other over the years. I fully expect the dual battery system in my defender to die before I sell the car.
If there is a requirement for a battery to run a fridge, mounting a gel or lead acid battery charged by a DC/DC charger is all that's required.
I hve had no issue with underseat batteries over many years. Always optimas.
Vehicle: Vitara SV420
Post Posted: Thu Apr 23, 2015 1:04 pm
I agree, I have a dual battery system set up in my personal work van. A simple 140a VSR connected from my starting battery to a 100ah AGM with Andersons just behind the drivers seat. The battery runs a 80L compressor fridge, electric oven, tool battery chargers, and a 240v invertor. I switch the fridge on for work Monday morning, and stays on all week until home Friday night, so running around 100 hours a week. The oven, chargers and invertor are only switched on as needed. I bought the van new and installed the system the day I got it home, so this set up has now seen 99,937kms and 4.25 years of use as of today, and I have not one issue or have I had to touch it. No DC-DC or anything fancy. It cost me around $400 all up to do, and still works as well as the day I fitted it. Not too bad for around 22,000 hours of use and still going strong! :D
Also I have just fitted the same set up into my SWB Vitara with my new battery box. viewtopic.php?f=14&t=49787
But with the battery behind the back seat.
Users browsing this forum: Google [Bot] and 169 guests
