It is currently Sat Oct 24, 2026 11:14 am
Vehicle: 82 Sierra 1.0
Post Posted: Sat Apr 18, 2015 9:12 am
Hi guys, about a month ago I got my hands on a tidy, super low mileage 1982 sj410 (the one in my avatar) and have truely been bitten by the bug. It already had 31" mt's and 2" ome springs but some serious scrubbing issues, so quite quickly got stuck in to try and solve it.
Iv spaced the wheels out and fitted 2" longer shackles and changed the shocks as the standard ones were near fully extended, so now it's pretty flexy and rolls great over fairly even ground but as soon as u get some articulation on the go the front tyre will get jammed up against the back of the inner guard.
So iv done a little careful beating of the seams and inner panels, which has improved but not solved the problem. I know I need to regretfully extend the bumpstops a little, but I'm thinking to get enough clearance I'm Gona need to do a bodylift.
What are your thoughts, anyone been down the same route for this problem?? I'd be thankful for any advice! Desperate to get this rolling right asap as iv got 2 weeks off work soon and feel a 4x4 camping holiday is on the cards :)
Post Posted: Sat Apr 18, 2015 11:30 am
Best bet will be redrill spring perch to move diff forward a bit then virtual lift the guards
The firewall can be moved back about 2in by cutting open the corner then belting it back. Cutting guard to suit then weld it back up
Vehicle: Drover pickup turk
Post Posted: Sat Apr 18, 2015 2:30 pm
Here's the virtual lift thread - viewtopic.php?f=5&t=34550&hilit=cut+guard
I like the tuna here
Post Posted: Sat Apr 18, 2015 5:19 pm
Thanks for the replies! I picked up some rubber for the bump stops today so il get that sorted and see how far off I am.
To be honest I'm not too keen on the task of moving the diff forward, I'm a paint sprayer by trade but after many years of been locked in the booth my mechanical knowledge is pretty basic.
I like the idea of the cut and shut guards though they look pretty sweet in that thread! If I'm still scrubbing like mad once the bump stops are in place I think il have a crack at that!
Cheers guys
Users browsing this forum: Google [Bot] and 183 guests
