It is currently Sat Oct 24, 2026 9:46 am
Vehicle: Suzuki Jimny
Post Posted: Sun May 24, 2015 9:35 pm
Does a tow bar have to be wired to the rear lights even if I'm never going to tow a trailer? I'm only going to use it as a recovery point and won't ever have a tow ball attached.
Post Posted: Sun May 24, 2015 9:46 pm
Tow bars arnt ever wired to the car, there is however a plug next to them usually, that is wired to the car.
I would think even if it were illegal to have one without the other, you would never ever be pulled up for it, unless you were towing.
You could just bolt on a recovery point though, probably lighter.
Post Posted: Sun May 24, 2015 9:50 pm
Thanks, how heavy would the towbar be? 15kg?
Post Posted: Sun May 24, 2015 9:57 pm
No idea to be honest I don't have one,
It's not going to be a great deal, just seemed if the only reason you wanted one then a recovery point could be easyer.
I say "could" because then you get in to a mine field of trying to get one that is designed well ect.
There has been lots of discussion on hear about recovery points. And no definitive answer on what's best.
Post Posted: Sun May 24, 2015 10:02 pm
Yeah, that's why I'm looking at a towbar, they seem the least criticised
Vehicle: LWB Sierra
Post Posted: Mon May 25, 2015 9:06 am
Just run the towbar, wire it up if you want but if you never tow anything it's a bit of a waste of time.
Angus
Platinum Supporter
Platinum Supporter
Vehicle: 2010 jimny
Post Posted: Mon May 25, 2015 9:08 am
i would suggest getting a towbar with a loom. it will be a similar price if buying new and even if you don't install the loom it will be better for resale value.
Post Posted: Mon May 25, 2015 10:03 am
Oh well, it's down to me to bring the hate then :D
Two things to consider with a tow bar primarily as a recovery point.
(prefaced by saying yes, 100%, it's the safest of the easy options)
The Hayman Reece towbar puts the 40X40mm receiver under the car in a place it's forever getting hung up on stuff. It's a shame to have a car with probably the best departure angle of any 4WD on sale and then wreck it with a towbar.
The 40X40 receiver is too small to easily thread a strap into. Adding a recovery adapter+shackle worsens the departure angle problem, adds heaps of weight, and does nothing to improve safety.
Just providing some other feedback.
Platinum Supporter
Platinum Supporter
Vehicle: 2010 jimny
Post Posted: Mon May 25, 2015 10:26 am
steve just told you to get a rear bar made with a 50x50 hitch receiver. lol
Post Posted: Mon May 25, 2015 11:11 am
Thanks Gwagensteve, the hate is the best bit! I'm getting a second hand towbar so resale isn't important. As for the departure angle, it's an alright compromise IMO coz if I get stuck, I can get unstuck. I was recovered twice off the front tow point (not rate recovery point or tie down) and it doesn't feel safe. And the rear bar would be great but I'm a cashless uni student at the moment so I can't buy good things hahaha
Post Posted: Mon May 25, 2015 11:15 am
all cool, but needing to get recovered using the dicey front recovery point because your'e stuck on the rear recovery point seems a bit counterproductive.
I don't have an answer -I don't own a jimny and would custom build whatever I needed in any case - but it's just something to bear in mind. For a temporary/cheap solution it's perfectly acceptable, it's just less than ideal.
Post Posted: Mon May 25, 2015 11:19 am
I used the front hook to get pulled up a rut that I kept bottoming out in
Users browsing this forum: Google [Bot] and 126 guests
