It is currently Fri Oct 23, 2026 11:00 am
Vehicle: Want a zook
Post Posted: Sat May 23, 2015 5:25 pm
Probably a stupid question but here goes.
On the drivers side chassis my suzuki Sierra has brake lines running along it front to back.
These are attached to the chassis at a couple of points with clips which clamp about four parallel lines in them.
Just next to the master cylinder I want to take the clip off so I can fit rock sliders with a c clamp on to the chassis then reattach the lines and clip.
However I can't work out how to take the clips off. They have a 5mm hole in the middle of the clip and there's something in it but I can't see if it's a tiny socket or what is holding it on the chasis.
Any ideas. Cheers
Post Posted: Sat May 23, 2015 6:08 pm
I think they just pull off from memory. The bit inside the hole is a sort of threaded stud the clip grips.
Post Posted: Sat May 23, 2015 7:39 pm
Cheers. Will try that if no one else says different. Just didn't want to stuff it up :-)
Post Posted: Sun May 24, 2015 8:33 pm
I think they are a bolt welded to the chassis
The plastic clip pushes on but i dont know if they come back off with out braking
Users browsing this forum: No registered users and 120 guests
