It is currently Fri Oct 23, 2026 4:52 am
Vehicle: 1994 Suzuki Vitara LWB
Post Posted: Fri Jun 12, 2015 12:30 pm
Hi guys.
What I am wondering is if it is worth upgrading my alternator in my vitara? Or if. I should just get it rebuilt.
Its a 1994 LWB Vitara (G16B) with what I assume to be the standard alternator...
It currently is not running anything that isn't stock... But it will soon be getting a list of mods.
These being:
2x 100watt spotties (wired to their own switch)
2x 55-80watt driving lights (not 100% settled on this yet, but again wired to their own switch)
Aftermarket head unit
Active slimline sub
And the two head lights/high beams
It already has a dual battery set up in it with a decent sized deep cycle battery in it if that helps...
Thanks guys.
Post Posted: Fri Jun 12, 2015 12:32 pm
I would fit a falcon alternator over a Suzuki alternator regardless of use. There are no disadvantages.
Post Posted: Fri Jun 12, 2015 12:39 pm
Thanks for the advice mate. I was thinking of doing it, but mainly didn't know if I am capable of doing it haha. I'm only capable of basic mechanics and I have no idea with electronics haha.
Post Posted: Fri Jun 12, 2015 12:43 pm
If you can remove the standard alternator and drill a hole, you can install a falcon alternator.
Post Posted: Fri Jun 12, 2015 1:37 pm
On top of that, you also need to be able to join a few wires, use a grinder, and possibly sketch a line.
The vit alt bracket may need a bit of material ground away.
Also the top sliding alt bracket needs a bit of grinding, helps if you sketch on it what needs to be removed.
Its very easy.
Post Posted: Fri Jun 12, 2015 1:38 pm
:oops: Well yes, I was paraphrasing
Still a pretty simple mechanical job.
Post Posted: Fri Jun 12, 2015 2:24 pm
Alright thanks guys, I think I should be able to do all that haha.
Next question... Is there any difference between the 100amp el alternator and a 110 amp fairmont ghia? Besides the obvious difference of 10amp, are they physically the same to install? The extra 10 amp doesn't really seem worth the extra money to me thats all.
Post Posted: Fri Jun 12, 2015 7:57 pm
Physically identical. Just fit whichever you find in best condition at a wreckers.
Post Posted: Fri Jun 12, 2015 8:14 pm
Thanks for the help :)
Ive got a mate who has a low k el he is wrecking and said I could have the alternator for $50 along with any of the wiring I need so I will probably grab the fuse box and the wiring that goes with it :)
Post Posted: Fri Jun 12, 2015 8:29 pm
Good call.
Vehicle: Vitara 1990 SWB Soft Top
Post Posted: Thu Jun 18, 2015 10:43 am
Paraphrasing again? :rofl:
Getting you a tape measure for christmas hahaha...
But yeah all the holes and pulley line up... so identical :lol:
Post Posted: Thu Jun 18, 2015 10:45 am
The 100a and 110a falcon alternators are physically identical. There is no difference from an installation perspective, which was what the OP was asking.
Post Posted: Thu Jun 18, 2015 10:49 am
Soz... I shall pull my head in... I thought you meant as compared to the original alternator ... :oops:
Vehicle: 1996 suzuki vitara
Post Posted: Sat Jul 11, 2015 9:34 am
So what is required to fit the alternator up? Anyone got photos of the process
Vehicle: Drover pickup turk
Post Posted: Sat Jul 11, 2015 11:05 am
Have a look at the falcon thread - viewtopic.php?f=17&t=5529
Steve shows pics of the modded g16b bracket.
I like the tuna here
Vehicle: SJ70 Tintop, SJ51T, 97 Coily
Post Posted: Sat Jul 11, 2015 7:10 pm
I could be mistaken but don't you need the Mitsubishi brand alternator as opposed to the bosch also?
Post Posted: Sat Jul 11, 2015 7:17 pm
Correct. Mitsubishi not Bosch.
Users browsing this forum: No registered users and 147 guests
