It is currently Sat Oct 24, 2026 2:35 pm
Vehicle: 2012 SUZUKI JIMNY M18A AUTO
Post Posted: Fri Jun 19, 2015 12:03 pm
Hi all...I had a quick look around but did'nt really find much info...does the M13A inlet manifold have smaller ports than the M18A inlet? I have a small flat spot with my jim and I am still running the M13A inlet manifold but I do have a M18A throttle body on and also made the TB diameter larger on the inlet using a Dremel to suit the larger TB. Most times it runs great but with snap open throttle it lags for approx 1-2 seconds before taking off and I was wondering if a port mis-match would cause this or perhaps lack of airflow? I also have a K&N filter but these filter housings are small so I am unsure?
Any thoughts appreciated.
Tanku
Vehicle: zook
Post Posted: Fri Jun 19, 2015 9:03 pm
Sounds like sensors/regulators related to fueling.
Are you using the M13 ECU or an M18 ECU?
check fuel pressure regulator and the vac lines running to it
are you using aftermarket extractors? check O2 sensor is sitting deep enough in the exhaust flow or check/replace o2 sensor
Users browsing this forum: Google [Bot] and 82 guests
