https://auszookers.com/forum/
hi, im new, wanting info on an elec dizzy
https://auszookers.com/forum/viewtopic.php?f=5&t=50367
Author:  slimer13b [ Fri Jun 19, 2015 7:17 pm ]
Post subject:  hi, im new, wanting info on an elec dizzy
hi, ive got a Holden Scurry/suzui carry with the F10A 4 cylinder motor in it. wanting to know if there is any place in Australia (if possible) that sells the electronic ignition set ups
Thanks heaps.
Author:  Gwagensteve [ Fri Jun 19, 2015 8:19 pm ]
Post subject:  Re: hi, im new, wanting info on an elec dizzy
I threw a 1.3 (g13b) distributor on mine, which run electronic ignition. Never got it fully sorted but others have.
Author:  slimer13b [ Fri Jun 19, 2015 9:50 pm ]
So do the G13B ones bolt straight in?
Author:  Gwagensteve [ Fri Jun 19, 2015 10:11 pm ]
Did on my f10a, but mine was in a sierra.
Author:  slimer13b [ Sat Jun 20, 2015 12:38 am ]
So no reason why it shouldn't fit mine yeh?
Author:  Gwagensteve [ Sat Jun 20, 2015 10:22 am ]
No idea- I have no experience with the carry version of the F10a
Author:  slimer13b [ Sat Jun 20, 2015 8:18 pm ]
arent all F10A engines the same?
Author:  Gwagensteve [ Sat Jun 20, 2015 8:22 pm ]
Maybe- pretty sure I've seen an f10a with the distributor facing the opposite way to the sierra version.
Author:  ZUZUKI [ Mon Jun 22, 2015 12:04 am ]
I'm assuming it currently has points, as otherwise you wouldn't be asking about a kit.
I just fitted a kit at Piranha Off Road to a 1.0litre points distributor, easy, bolt in kit, costs $320.
I work there - not saying buy our kit, but we do sell one to suit.
An alternative, is that the F10A Maruti versions in the 1990s ran an electronic ignition distributor - might be able to either fit those bits into your body (if the body is mounted differently in a van) or just fit the whole thing + module.
Cheers, Michael V.
Author:  slimer13b [ Mon Jun 22, 2015 12:40 am ]
yeh mine is points set up
https://www.google.com.au/search?q=suzu ... B557%3B538
Author:  fordem [ Mon Jun 22, 2015 1:34 am ]
No.
I believe the block & head are identical, but, the remainder may differ significantly depending on the vehicle. A Sierra (or Maruti) will have the engine mounted, more or less, vertically, but the Carry vans have it tilted at a significant angle, under the front seat.
Oil pans are different, intake & exhaust manifolding is different, as Steve has pointed out, the distributors are mounted differently - who knows what else is different.
