It is currently Thu Oct 22, 2026 6:07 pm
Vehicle: Suzuki Vitara SV420
Post Posted: Sat Jun 27, 2015 12:03 am
Hi all,
Just looking for a bit extra power on my 1.6L Vitara. Enjin is still stock standard, just thinking of an carburator upgrade ?
Any simple suggestions ?
Vehicle: SJ80, SE416
Post Posted: Sat Jun 27, 2015 1:07 am
Your profile mentions a '98 Vit. All Vits in '98 were EFI - so no carburettor.
How much work do you want to do to get a 'bit' of 'power'? Done the mechanical basics?
Post Posted: Sat Jun 27, 2015 1:21 am
Hi Reubs, was just a typo. Fixed it now.
I don't want to open the motor for now. Thought i could just put a DCD Weber on or something ? Just bought it, done nothing yet.
What would you recommend ?
Vehicle: 91 Vitara SWB Soft Top
Post Posted: Mon Jun 29, 2015 8:22 am
I fitted a 6in x 2.5in round air cleaner and ditched the factory air cleaner and i gained 2 seconds off my 0-60kmh time, i went from 9.5s to 7.5s
i am also booked in for extractors and a new exhaust next week and i changed the vacuum secondary pipe to constant vacuum and apart from a big flatspot on full throttle it goes so much better on the freeway
those times are with 31in m/t's fitted
0-100km went from 26s to 22s too
also if i do a dirt road or weekend 4x4 trip i'll put the factory aircleaner back on so i don't get water and mud in the carby.
i tried running different fuels and advancing the timing but didn't get any noticeable benefits, so standard timing and 91 octane is all i need
Post Posted: Mon Jun 29, 2015 8:42 am
Unfinished- you're leaving a lot of torque on the table if you don't advance the timing for 98 octane.
Post Posted: Mon Jun 29, 2015 8:57 am
i did advance it but it didn't go any better, i get the same performance on std timing and 91 octane, i'm sure once i get the extractors and with the new air cleaner it might have more of an effect
Post Posted: Sat Jul 04, 2015 12:49 pm
How much advance did you add, when I was playing earlier, 32/36 weber, hot ignition, and extractors, found much better go by upping initial timing to 12 degrees BTDC, I also went to 1.1mm gap plugs not the 0.8mm stockers.
Users browsing this forum: No registered users and 111 guests
